My Dad Has A Question
My parents have a 97 CR-V, which is the B-series motor. The idea me and my dad had is, when the engine goes dead in the CR-V, take it out, rebuild it, use it in another car. The questions are this. Can vtec be added to this engine? Would an s2000 transmission work with this engine? He wants to put it in a real wheel drive car right.
Yes it can have vtec, it will require a vtec head from another B series motor. It cannot work with s2000 transmission without a ton of custom work, it would not be worth it.
I dont really understand what you're trying to build but it honestly doesn't seem like you know either..?
My dad wants to build a 32-36 ford with a honda motor. I suggested takin the CR-V motor and rebuilding it for the car, cause I thought it was a K-series engine. I looked it up, and only the newer CR-Vs are the K's. My bad on that hah. He still thought it would be cool though, super gas mileage was the idea, with a fairly fast car, cool looking car.
What kind of custom work would be needed? Crazy custom work? The engine would probably be much better than the F20 on gas anyways.
IIRC the B series engines spin the wrong way. So when he gets the engine hooked up to the axle in his chassis he will have five or six reverse gears and one forward gear. Not exactly useful.
AFAIK, all Honda C, F, J, and K engines spin the correct way and would be good candidates to adapt to a longitudinal transmission.
Adapting these engines to a T-5 transmission could be the way to go. It's a light, relatively strong transmission in WC/World-Class form. They have a bit of a bad reputation in muscle car circles but I can't see any stockish Honda engine having enough torque to break it. You would have to make your own adapter.
I'm not certain if Honda uses the same bellhousing pattern as Toyota. If they do then it should be possible to adapt any of the Aisin-Warner transmissions to the Honda engine.
This is all speculation on my part. IF you have an image of the bell pattern on the engine you could browse this thread:
http://www.jeeps-offroad.com/showthread.ph...wap+bellhousing
to see if there are any similarites as this has a big Toyota overlay to it.
If you don't follow what I'm talking about, just do a F20 with six speed. Tons easier. The difference in MPG between a B and a F driving a brick like a 1930s car through the air is probably not measurable.
I'm mildly interested in this. I've been thinking about adapting a J engine to a Jeep AW4/ Toyota A340 transmission. All my Jeeps are under 200k kms though so it's just a pipe dream until they get to at least 500k kms. If you pursue this let us know what you come up with.
HTH
HTH
