Seized my engine
Damn Jeff. That sucks.
I agree with mike. definitely need a baffled pan if you’re pulling some good Gs. My guess is you’ll have some cylinder wall scoring as wel but I have seen the odd engine just need bearings. Do you have an oil cooler? What were your oil temps? What oil were you running?
Thinking back to last year, going into turn 1 I could feel loss of power for a brief time. I had no idea what it was, but now it makes sense it was oil pressure related. Fast forward to this year I was dealing with some bogging in vtec, makes sense now
do you think a baffled pan could be the difference maker from this happening again?
Hi Nick, yeah it does. My own neglect and naivity is to blame. I wasn't running any oil cooler, temp or pressure gauge. My next motor will have oil pressure at least. Was running day old 10w30 Amsoil ss. Previous oil change showed no bearing material so that might give some insight into the time frame and condition of rest of motor, but since it seized I am expecting the worse case.
Thanks Joey.
I cut open the oil filter and drained the oil. Reminded me of the gold rush in California.
pulled the valve cover.looks fine as far as initial inspection. Little bit of debris in the solenoid screen.
Will drop the pan when I get some time. Do I need to disconnect the transmission for that?
Going to put a bore scope down the cylinders and see how those look.
Good luck going forward pal. I hope it isn't as bad as it sounds.
Joey
Damnnnn, sorry to hear J. I'll buy your spare parts I still have with me, put the funds toward the rebuild. Let me know.
We can learn from this thread, subscribed, keep us posted J. Best of luck.
just thinking out loud here. Oil pressure gauge. Baffle. Oil cooler.
what are all the track junkies setups?
The ballade baffle looks to be the easiest since it can be bolted in.
Where is everyone monitoring oil press and temp from? The stock oil dummy location looks like a good spot
thanks everyone. Nothing new to report yet.
