Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Weird Clutch feel
Old 05-01-2017, 03:10 PM
LemonJus's Avatar
Originally Posted by hawkman199
If your clutch fluid is boiling, your car is probably on fire.
The clutch slave is mounted on the outside of the clutch housing and only gets a bit of heat soak from the transmission. Generally, it would only be a few degrees over ambient temperature.
It gets dark quickly because of the crappy rubber hose going from the master to the slave and the so-so seals.
I change mine every couple of seasons.
I still do mine every year while I'm getting the brake fluid done at the beginning of the season... figured, might as well.
Old 05-02-2017, 04:46 AM
hawkman199's Avatar
Originally Posted by Chuck S
Change what? Fluid I'm guessing?
-- Chuck
Yup, fluid. Were you thinking lines and seals?
There are SS braided lines available for the clutch. Not sure if they are any better than the stock lines.
Old 05-03-2017, 03:10 AM
myflys2k's Avatar
My old AP1 had symptoms like this. The clutch throw out bearning grease was all dried up.
tampaSuzuka
02-09-2010 04:36 PM
hellspare
01-12-2010 01:34 PM
epaplia
10-20-2008 10:16 AM
bunz559
09-26-2007 11:14 PM
SilverstoneS2k_FL
01-12-2005 08:18 AM
Quick Reply: Weird Clutch feel
