Who's Running An Oil Pressure Gauge ?
I tried a search of oil pressure gauges and got mixed results. I'm just wondering if anyone here is running a reliable high quality oil pressure gauge. I'd like to run one to monitor pressures rather than waiting for the factory "your engine is toast" light to turn on after the damage is done.
Price isn't a concern, quality and reliability are most important. I won't be running any other gauge so I need something that just works on it's own. I don't care about data logging capability as I wouldn't have a need for that. I'd appreciate any reply and pics if possible, thanks for reading.
As you probably already know I'm running an oil pressure gauge. It's added to the aem ems and displayed through the serial gauge (19 in 1). It's actually probably the best setup just because you can program the ems to shut off the car if the oil pressure drops below a set value, to prevent further damage.
I've used plx gauges before but found the pressure reading unreadable as it bounced around on the LCD screen. There are a handful of gauges out there that will work on their own. Like this one
http://www.aemelectronics.com/oil-pr...to-150-psi-768
My gauge is mounted in the radio controls where the mode button use to be. It's right in view but not in view of passing cars. IMO it's the best spot for a gauge. I never used the mode button anyways and all the other controls work as normal.
Also forgot to mention that the sensor is mounted in a greddy sandwich adapter. I read oil pressure and feed oil to the blower from there. Oil temp is measured at the pan drain bolt.
I'll start looking for a mounting spot, I'd like to keep my radio controls if possible. Thanks bud
It's funny that you posted this because i remember the discussion about the S2000 for sale with an oil pressure gauge and the speculation that it was previously boosted. Sometimes people just want to know what the oil pressure is
Sending a pm for more info.
