Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Wind noise over 100km - Soft top not as tight as before
Old 03-23-2018, 07:54 AM
Himura357's Avatar
Default Wind noise over 100km - Soft top not as tight as before
Hey guys,
The AP1 has the original soft top latches and I get wind noise over 100km/h. If I manually pull the top down it goes away.
Is this just the soft top latches going bad? I read some people add washers or something to close the gap?
Anyone have this issue and fixed it? New soft top latches are not too expensive if I'm not mistaken. Hopefully its just that.
Thanks!
Old 03-23-2018, 09:03 AM
haga888's Avatar
You might just need to add a shim or two to the existing ones.
Old 03-23-2018, 09:46 AM
Himura357's Avatar
Is it just the strikers/latches getting old that creates this problem?
Old 03-23-2018, 10:39 AM
haga888's Avatar
I believe so. I think it's a regular wear part metal on metal.
Here's the shims Honda sells:
https://www.hondaautomotiveparts.com...ZC1tYW51YWw%3D
Himura357 (03-23-2018)
Old 03-24-2018, 07:39 AM
zeroptzero's Avatar
Received 3,358 Likes on 2,441 Posts
The striker plates are likely the issue, they wear faster than the soft top latches, I'm sure the latch hooks are a harder metal. I might have a couple spare strikers I could send you for free, they are used but likely in better shape than yours. A simple trick is to add washers under the striker plates, I had to do that on my car to stop the rattles, it is a simple trick and works as it pulls the roof tighter. You just remove the striker plates put a decent thickness washer under the striker plate and then reinstall it, 2 washers per striker plate, it is a simple test if it works then great, if not then you haven't spent anything. The trick is getting the striker plate bolts out without stripping as the factory used Loctite on them, you need a big ass phillips screwdriver and push up with force while turning, or use an impact driver which works the same way, small screwdrivers won't give you the needed torque and can strip out.
Himura357 (03-25-2018)
Old 03-24-2018, 11:29 AM
starchland's Avatar
Can the striker plates be swapped? If you look the wear area is on different on each side
Old 03-25-2018, 05:57 AM
S2K Type R's Avatar
Yes, that is one of my suggestions along with washers and on the hook side, some people put on a silicone tube to increase its thickness.
Old 03-28-2018, 06:30 AM
Royaltrophy's Avatar
My personal experience with this was back and forth swapping between both sides, putting washers under both striker and the lever, bought used strikers switcheroo and rain dance before and after but NOTHING WORKED quite like just pony up and buying a new set.
The moment I installed the new parts the problem was gone and the roof latched down super tight. No more wind noise or rattles.
Old 03-28-2018, 10:51 AM
zeroptzero's Avatar
That is pretty much the right answer and ultimately what may be needed.
Poe408
11-20-2014 07:54 AM
caskin
11-15-2010 12:37 PM
levitronix
11-02-2008 05:23 AM
Quick Reply: Wind noise over 100km - Soft top not as tight as before
