***ZEITRONIX PRODUCTS MADE IN USA!***
Hi guys,
we would like to announce that we here at kamispeed are officially a zeitronix dealer and would like to share with you some background on this great company, one of the very best choices for your tuning solutions.
About Zeitronix
Zeitronix has been a part of the racing scene for many years. We support race teams in US and around the world. We have been offering high grade automotive electronics available to high performance enthusiasts and wining race teams since 1998.
To assure the highest quality of our products are designed using tough military standards and industrial derating guidelines. We strongly believe that consumer grade electronics has no place in tough automotive environment. Our engineering group has years of experience designing military, medical, automotive and industrial electronics. Using modern, state of the art surface mount assembly equipment and process control adds additional level of robustness to our products.
All our products are designed, manufactured and fully tested in USA. We do not take any shortcuts!
Warranty
Our products carry 6 months manufacturing warranty. If you have problems with our product contact us, 99% of all issues can be resolved remotely. All returns and warranty repairs need to be authorized. A 10% restocking fee will apply to all returns. All returns must be received in new unused condition within 30 days of original purchase date. Shipping charges are not refundable. We do not warranty or refund sensors. Our products are fully tested and made in the USA.
This year at the 2009 SEMA Auto Show, Zeitronix was very honored to receive awards for both the Zeitronix Ethanol Content Analyzer and the Zt-2 Model 2010 Wideband Datalogging System. The Ethanol Content Analyzer was the winner of a 1st Runner Up award in the “Best New Performance Racing Product” category and also received a SEMA “Global Media Award” from international journalists. The new Zeitronix Model 2010 Zt-2 Wideband System also received a "Global Media Award". Zeitronix products participated in a a field of more than 2700 new products at this years show.
Here are some pictures of the Zeitronix guys at sema last year
The Award Winning Zt-2 Model 2010 Wideband Datalogging System The Zeitronix Wideband Air/Fuel ratio meter and datalogging system is a high quality, stand-alone system for use with carbureted and electronic fuel injection engines. Zt-2 Wideband Kits provide the best bang for your buck delivering unmatched quality, features and capabilities for very reasonable prices. Our system provides the accuracy of a Dyno Air/Fuel reading right in your vehicle as well as multiple engine parameters. Our base system is very easy to install and retails at $279 which includes:
Supports: Air/Fuel ratio as AFR/Lambda, plus RPM, Vacuum, Boost, Exhaust Gas Temperature, Throttle Position, 0-5 volt sensors, and Air/Fluid temperature sensors. Tune fuel injected and carbureted engines. Very simple installation. Connect two wires to +12V and ground and place the O2 sensor in the exhaust stream and you are ready to read AFR!
Cut your tuning time in half!
No matter if you have a stand alone engine management system, a piggy back fuel control or a carbureted engine. The Wideband Air Fuel Ratio Meter is a must for a serious tuner! Finally you can tune for more power, closer to the edge, precisely monitoring Air/Fuel ratio Boost, EGT, RPM and throttle position datalogging up to 9 hours of data with a blazing rate of 74 samples per seconds per graph. The ZDL software can be utilized as a real time display when using a basic Zt-2 kit without the hardware display.
Fully digital, smallest wideband O2 controller and datalogging system in the world!
Zt-2 is about the size of 1" thick business card.
Extremely compact design for installation where space is a premium.
Zt-2 Specs
The Zt-2 communicates with the PC Laptop via the serial port. The ZDL logging software records up to 9 hours of data per single file. Different screen options are available. It has a black background for easy night tuning. The logging start, stop and pause accessible from keyboard shortcuts. Excel and text data export.
Win98/NT/2000/ME/XP/Vista/Windows 7 compatible.
You do not need P4, P3 or even P2 laptop. We understand that you want to leave your new laptop at home and dedicate the old one to car tuning. We give you well optimized software. If your laptop is capable of running Win95 and up it is good enough for the Zeitronix logging software.
The digital gauge screen option could be used when purchasing the Zt-2 without the LCD display.
The EGT Sensor
Zt-2 reads the exhaust gas temperature through a standard K thermocouple, the same as used by most aftermarket EGT gauges. You can retrofit your EGT probe with supplied Zt-2 style 2 pin connector or purchase a new probe from us. Moreover, we offer 8' chromel-alumel extension wire with the Zt-2 style connector in case you need to extend your EGT probe.
FOR MORE INFO CHECK OUT ZEITRONIX PAGE
Please let me know if you have any question regarding the products, guaranteed Quality will exceed expectations!
ZR-2 Multi Gauge
The Multi Gauge works with all versions of the Zeitronix Zt-2 Wideband AFR meter and Datalogging System. The ZR-2 plugs into the Zt-2 DATA port. For clean and easy plug and play installation, power and serial data is supplied from the Zt-2 DATA port. There are no additional +12V or ground wires. The ZR-2 cable length is 5 ft (1.5m)
MOUNTING OPTIONS
The ZR-2 gauge is only 6/8" (19mm) thick. The back of the gauge is completely flat with cable hidden in a cavity and can be surface mounted almost anywhere inside the car cabin using a piece of Velcro or double sided tape. The ZR-2 base allows the gauge to be mounted in a standard 2” 1/16 (52mm) gauge pod. For additional mounting options the package includes 2 set screws and 2 nuts.
ZR-2 gauge dimensions:
Base diameter 2" 1/16 (52mm)
Bezel diameter 2" 1/2 (62mm)
Thickness 0.75" (19mm)
Digit height 0.3" (7.5mm)
<span style='font-size:7pt;line-height:100%'>Zeitronix Wideband LCD Display</span>
Display Features
- Display LCD top line as: Lambda and AFR / User2 and AFR / Lambda and U2 (User2).
(User2 can be setup as: Oil/Air/Water Temperature, Oil/Fuel Pressure, and Boost!
- Display LCD bottom corner as Boost, Throttle Position, or User1 (0-5 volt sensor).
- Display in imperial or metric units.
LCD Setup Overview
Yes, you can be fast without the A-pillar gauges. The LCD display gives you a stealth look and important data in high contrast digital format. The aluminum enclosure dimensions are 4.7" x 2" x 0.9" , slightly larger than the LCD display itself. The LCD fonts are bright white on a black background. High contrast LCD digits are visible even in a direct sunlight. A push of a button located on the right side of the LCD shows peak and hold maximum AFR, Lambda, EGT and Boost values. The LCD display communicates with the Zt-2 digitally through a serial interface. This allows for a clean display installation in the car, since all heavy wire connections are going to the Zt-2. The display serial cable is thin, black and easily blends with the dash. The new overlay is made from hard coated, scratch resistant material.
Zeitronix DashDAQ Series II XL Display
Full color, OBDII compatible Touch Screen Display for the Zt-2 Wideband AFR Meter
About Zeitronix
Warranty
- the wideband oxygen sensor
- controller
- wiring hardware
- and the software required to start datalogging and tuning
Zt-2 Specs
- 0.1 AFR accuracy
- Operating voltage 10V to 18V
- Switching power supply for oxygen sensor heater
- Precise sensor temperature control
- Reverse polarity protection
- Integrated self resettable fuse
- Positive lock connectors
- Protected inputs and outputs
- Flexible Plug and Play Sensor Harness with a small, easy to route through the fire wall, connector
- Wideband Oxygen Sensor included
- Easy to install plug and play kit
- Adjustable Narrowband Switching Point
- Warning Alarms and Triggers
- Bosch Wideband O2 sensor
- Linear Wideband Output AFR=Vx2+9.6
- Serial data output to the Zeitronix Wideband LCD Display
- Serial data output for real time datalogging (PC laptop required)
- RPM Input (tachometer, primary side ignition coil, crank, cam sensor).
The RPM input works in any car and any ignition system. No additional adapters needed! - Simulated and adjustable Narrowband Output to feed a stock ECU
- Throttle Position Input
- Boost (MAP) Sensor Input
- EGT Probe Input
- User Input
- User2 Input, Programmable to view/log 0-5V, Fuel Pressure, Oil Pressure, Boost Pressure, Water Temperature, Intake Air Temperature, Oil Temperature, Transmission Temperature. (Zt-2 model 2010- viewing supported in new LCD, ZR-2 gauges, and logging software)
- Warning Output
- 5V output for sensors
The EGT Sensor
ZR-2 Multi Gauge
- One gauge for displaying Wideband AFR / Lambda, Boost / Vacuum, EGT, and "User2" input (air/oil/transmission temperature, fuel/oil pressure, or voltage)
- 4 digit readout (available in Blue or Red)
- Stylish, machined, brushed aluminum or anodized black bezel and slim enclosure gives the gauge an elegant appearance
- User configurable outer LED and inner digital readout values via a front push button
- Gauge startup setup is configurable
- No PC laptop required for gauge configuration. You can cycle through displayed values at any time using a front push button
- English and Metric Units
- High contrast LED display
- Large 0.3" (7.5mm) digits
- Slim, flat back, design for flexible gauge mounting options
- Peak and Hold feature
MOUNTING OPTIONS
Display Features
LCD Setup Overview
- Zeitronix-DashDAQ display is Preconfigured for easy Plug and Play use with the Zt-2
- Display and data log AFR, RPM, EGT, Vacuum/Boost, TPS, and User Input from your Zt-2
- Run a Dual Zt-2 configuration for left and right cylinder bank AFR values!
- 4.4" Touch-Screen offers 480x272 resolution using TFT LCD technology.
- 24-bit full color display with contrast ratio of 350:1
- Dimensions are 5” x 3” x 1”, weight is only 0.5 lbs, (127mm x 77mm x 26mm, 275 grams)
- Full OBDII support for display of parameters such as Mass Air Flow, Spark Advance, Coolant Temperature, and many more! (OBDII is not required for use with the Zt-2.)
- Data logging support onto removable memory card -- no laptop or PDA required.
- Auto Adjusting backlight, night mode, and low power standby.
- Calculate Horsepower, Torque, 0 to 60 Performance, MPG and set configurable trip counters.
- Diagnose and clear check engine light error codes.
- OBDII and Plug and Play Zeitronix Zt-2 cables included.
- DashDAQ Zt-2 license included ($50 value)
- Simple and secure windshield-mounted display.
- NEW!!! Optional GPS support with NAVTEQ maps for US and Canada. Supports points of interest, turn by turn directions, and voice guidance!
