AEM's NEW Wideband Failsafe Gauge! MVP Motorsports
The Wideband FAILSAFE Gauge provides the ability to accurately tune AFR, while actively protecting your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy if it runs lean. The Wideband FAILSAFE Gauge is a Universal Exhaust Gas Oxygen (UEGO—“you-way-go”) controller with an internal boost sensor, an internal data logger and a full color Organic Light Emitting Diode (OLED) display. It includes technology to activate a failsafe strategy in the event AFR falls outside of a user-defined operating window. If the AFR falls outside of the set operating window, the Wideband FAILSAFE Gauge triggers a user defined output function that can save an engine from catastrophic damage. WHY YOU WANT ONE This product is a must have for all tuned performance engines, either forced induction or naturally aspirated, fuel injected or carbureted. Any high performance vehicle owners who want a highly accurate AFR tuning tool with logging and a protection strategy that can save an engine from catastrophic failure will want this FAILSAFE device. WHAT IT DOES After the engine is tuned and a safe operating window of AFR is established, the Wideband FAILSAFE Gauge continually monitors AFR and boost or vacuum to make sure that AFR does not fall out of the defined operating window at a given boost or vacuum level. If the Wideband Failsafe detects an out of range AFR reading, the gauge triggers a low side output (ground signal with a 1.5 amp draw max) that can save your engine from catastrophic damage. Use the gauge’s intuitive software to configure the low side output, create a user-adjustable time delay strategy to prevent false alarms, and customize the gauge lighting to flash and alert the driver if an alarm is triggered. Use the gauge’s intuitive software to configure the low side output and create a user-adjustable time delay strategy to prevent false alarms. http://www.aemelectronics.com/images..._Collected.jpg AEMdata On-Board Data Logging AFR Plot. http://www.aemelectronics.com/images...a_AFR_Plot.jpg Use the Auto-Set Limits Feature to speed the set up process. http://www.aemelectronics.com/images/WBFS_AutoSet.jpg Intuitive Gauge Configuration Tool. http://www.aemelectronics.com/images...figuration.jpg PM OR POST UP FOR S2KI PRICING!!!! Regards, Robert |
how much shipped to 91709?
PM sent!
Regards, Robert |
shipped to 15108 please
PM sent!
Regards, Robert |
how much for gauge and any necessary sensors shipped to 75248?
PM sent!
Regards, Robert |
Does this include the wideband sensors aswell?
Shipped to 78247 as a whole package please |
Yes sir it does, PM headed your way!
Regards, Robert |
how much for gauge and any necessary sensors shipped to 77066
