Ballade Sports Electronics sale
Hello S2Ki,
If you're interested in any parts of brands that you don't see listed here, please feel free to call, or email your inquiries. http://www.balladesports.com/wp-cont..._1-500x333.jpg A’PEXi AFC Neo Fuel Management $399.95 The AFC Neo marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful AFC Neo, the AFC NEO has taken piggy back style fuel control to a new level. The AFC Neo boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data, such as: RPM, throttle, battery voltage, correction %, air flow%, pressure (kpa), and karman sensors. The AFC Neo is the industry standard for sub computer fuel control. The AFC Neo is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make horsepower, the AFC allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The AFC utilizes a Color FED (Field Emission Display) to display critical data in three different modes. The AFC, while not completely universal, comes pre-programmed with 28 of the most commonly used air flow meter (hotwire type), 21 pressure sensor (map sensor type), 8 air flow meter (flap type) sensor maps. By setting the AFC to one of these programs, the user is able to adjust injected fuel amounts by +/- 50%. 8 or 16 user defined RPM adjustment points allow maximum tuning in 500 rpm increments. Fuel can also be adjusted for part and full throttle situations. The Deceleration Air Flow Correction cures erratic idle problems for Hot Wire vehicles equipped with an open atmosphere blow off valve. The AFC can also display an incredible amount of data including: Air Flow Capacity (Hotwire and Flap Type only), Engine RPM, Throttle Position, Pressure Sensor voltage, Karman Frequency and Air Flow Meter Correction. The AFC Neo displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. The Multi Mode displays up to two parameters in digital and one parameter in analog. Peak Hold is also included in this function. The Graph mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds. http://www.balladesports.com/wp-cont...2014/09/12.jpg Hondata 00-05 S2000 KPro $1520 The S2000 KPro includes a new RSX (PRB) ECU adapted for the S2000, and a wiring harness for the crank and cam sensors. It does not include the Honda parts. http://www.balladesports.com/wp-cont...ge-500x360.jpg Hondata Traction Control $595 Traction Control for your s300, KPro or FlashPro. Hondata Traction Control works by monitoring the ABS wheel speed sensors and reducing engine output when excessive wheel-spin is detected. A dash mountable switch allows the selection of different target slip rates, and software allows the system to be tuned for your specific vehicle setup. Compatibility ECU / EMS Coverage S300 (I or II) All ECUs / Models KPro (I, II or III) PRB & PRA ECUs including 2000-2005 S2000 FlashPro 2006-2011 Civic Si, 2012+ Civic Si, 2013+ ILX, 2006+ Euro Civic Type R, 2006+ S2000, 07-08 TSX and 09-10 TSX, 07-08 TL. http://www.balladesports.com/wp-cont...le-500x425.jpg Hondata Flashpro $694.99 Applications: 04-08 TL 04-10 TSX 06-09 S2000 06-11 Civic R18 06-11 Civic Si 07-08 Fit 07-12 RDX 10-12 CRZ 12+ Civic 13+ ILX Note: Please select the correct vehicle application needed before clicking "add to cart". The FlashPro allows full user tuning and datalogging of drive by wire S2000s. It includes Windows based software called Flashpro Manager. The FlashPro connects from your laptop's USB port to your vehicle's diagnostic port to provide real time programming, a variety of calibrations and extensive datalogging capabilities. http://www.balladesports.com/wp-cont...s2-500x375.jpg AEM EMS Series 2 – ECU Honda S2000 AEM''s Plug & Play Engine Management System (EMS) is the first of its kind and will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle''s factory ECU harness and requires no additional wiring or hardware. Windows-based software. User-defined templates are easily configurable and enable tuners to establish "quick keys" to any pertinent information during the tuning process. The AEM EMS''s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition. AEM Programmable Engine Management Systems are legal in California for off-road vehicles only and should NEVER be used on public highways. The AEM EMS is not compatible with the factory traction control system (TCS). http://www.balladesports.com/wp-cont...02-500x333.jpg Alloy Craft Honda S2000 ECU Bracket For AEM EMS Series 1 / 2 $44.99 Alloy craft Engine management mounting bracket for the Aem V2 and V1. These brackets mount the Aem V1 or V2 in the same location as the stock ECU. This helps keep the kick panel from bowing outward and keeps wire path as stock. These are formed from pre plated steel and powder coated black. Add USB Extension for $15.00 |
