Defi Advance CR and Advance BF IN STOCK at MVP!
Defi Advance Control Unit
Defi-Link ADVANCE Control Unit can control up to 7 Defi-Link Meter ADVANCE CRs and ADVANCE BFs all in at a time. (Ex. 4 ADVANCE CRs and 3 ADVANCE BFs)
Another GREAT feature introduced in the new ADVANCED line is the switch unit which allows you to conceal the ECU portion of the Control Unit and mount the key pad anywhere in your vehicle for a nice sleek look! Another great feature is with both fuel pressure gauge and boost pressure gauge installed, differential pressure can be monitored on the fuel pressure gauge screen.
Advance CR:
Available in 52mm or 60mm but with your choice of black or white face you can fully customize your interior by choosing your desired color! The illumination at night can be switched between 2 different colors (White dial: amber red / blue; Black dial: white / amber red) while the outer edge of the gauge illuminates in red at night.
Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit, or serial communication errors. A warning by buzzer will sound when the warning LED is on (buzzer can be turned on or off). Peak value and warning value during driving can be stored and replayed up to 3 minutes.
Advance BF:
Available in 60mm and Black face only, but with your choice of 3 LED Light Options - White, Amber, or Blue - to match most of today's modern dash illumination colors.
PM or post up for special package pricing on either series gauge with control unit!!! Please note that if you currently have the original BF series gauges you will still need to purchase the new control unit as the original control unit will not work.
Regards,
Robert
How much for 52mm racer gauge (the one that does not require a control module) Amber colored. If you have sensors as well please include in price. Shipped to 07110
Oil pressure
Boost gauge
Air Fuel
Oil pressure
Boost gauge
Air Fuel
EvasiveMotorsports
07-31-2009 12:50 PM
crackaonrice
Member S2000 Classifieds and For Sale
02-18-2008 02:16 AM
