Qstarz LT-Q6000 Lap Timer Group Buy
GROUP BUY PRICING PM FREE SHIPPING INCLUDED! https://www.evasivemotorsports.com/m...car-holder.jpg LT-Q6000 is an innovative and automatic Lap Timer based on GPS technology, which is the world’s first color display Lap timer device. It can record lap times, speed, position and acceleration, etc, and real-time compare the racing performance. LT-Q6000 fits all kinds of racing modes such as Drag Race, Circuit Race, Rally Race, or Performance test. https://www.evasivemotorsports.com/m...0001/QST-1.jpg 2.4inch. Color Display Large 2.4in. Color display to show and compare the racing data precisely and clearly. Real-time per split remind you are faster or slower than your best lap timing record by different color background. Green tells you are faster and Red means slower. This will be great for racers to adjust driving strategy in time. https://www.evasivemotorsports.com/m...001/QST-10.jpg Diversified Racing type Whether you are drag racing, circuit racing, single lap racing, rally racing or taking performance test, no doubt LT-Q6000 will be your best lap timer. Diversified Drag Race modes are selected by speed/distance no matter 1/4 mile 1/8, 0-100m or 1-400m,etc. Flexible Circuit Race is selected by Lap with splits or Simple Lap which racers can on-device compare multiple laps and splits. If they are not enough, don’t worry you can create your own type. https://www.evasivemotorsports.com/m...-Q6000-(2).jpg eXtreme 10Hz Log rate LT-Q6000 supports 10Hz Log to calculate the position of your vehicle ten times per second which is highly accurate for extreme racing sports. With high-sensitivity GPS and AGPS assisted, Q6000 is a stand-alone device which is very powerful and easy-to-use without hassle setting up. It can be also functioned as Data logger to log your travel route by either 1, 5 or 10Hz. https://www.evasivemotorsports.com/m...0001/QST-2.jpg Built-in G-sensor Q6000 is built-in G-sensor to plot G-force distribution and function Auto Start trigger. Q6000 support various start trigger modes by G-sensor, 5-second timer, 3-second timer and push-and-go. Just easy and Go! https://www.evasivemotorsports.com/m...0001/QST-3.jpg 2GB Large memory You will be No worry this device will be out of memory. Its history database is well organized as Calendar and table type for easily review. https://www.evasivemotorsports.com/m...0001/QST-4.jpg Function Capability: - eXtreme 10Hz Log to record 10 times per second - Real-time perform and display Lap Timing analysis - 2.4 True color and wide display to illustrate racing data precisely - Real time Lap/Spilt/Sector Comparison - Multi-Function Device – Lap Timer and GPS Logger - Start-Run by Push-and-Go, Timer, or Auto Trigger - Diversified Drag Race modes selected by speed/distance and kph/mph - Flexible Circuit Race selected by Lap with splits or Simple Lap - Performance Test On-the-Go - 2GB Large memory capacity never worry full memory - History database well organized as Calendar and table type for easily review - Flexible Track Manager – On-Device created to User track, and QRacing Sync to Shared track - G-force meter to plot G-force status - Smart speedometer to show real-time speed information - Device configurable such as unit, backlight, brightness, time zone, or time format - Support On-Device Export to KML, CSV or GPX files Hardware: - Adopt MTK II chipset with high sensitivity -165dBm and 66-Channel tracking - 2.4 (320x240) TFT Color display with 65K color - Ultra lower power consumption up to 10hrs operation (under LCD backlight on) - Log rate up to 10Hz excellent for High speed Racing (1) - Including 8 Function buttons – 4 Direction Buttons (Up/Down/Left/Right) / Back, Enter, Mulit-function, and Power Buttons - 3 LED Indicators – Green for Screen Power Saving, Orange for Charging, and Red for Alert - Built-in G-sensor for G-force measurement and Auto Start trigger - Built-in 2GB large memory inside - Device recognized as USB removable disk for data access with computer conveniently - Raise beeper function to notice some status of device - IPX-3 water resistance - Less than 15-Sec. AGPS fix support to realize faster TTFF and positioning - under warm start - Mini-USB interface for charging, data download and firmware update - Firmware upgradable - Device Dimension (LxWxH): 100 x 59 x 28mm - Device Weight: 107 grams (Mounting bracket excluded) Function Capability: - eXtreme 10Hz Log to record 10 times per second - Real-time perform and display Lap Timing analysis - 2.4 True color and wide display to illustrate racing data precisely - Real time Lap/Spilt/Sector Comparison - Multi-Function Device – Lap Timer and GPS Logger - Start-Run by Push-and-Go, Timer, or Auto Trigger - Diversified Drag Race modes selected by speed/distance and kph/mph - Flexible Circuit Race selected by Lap with splits or Simple Lap - Performance Test On-the-Go - 2GB Large memory capacity never worry full memory - History database well organized as Calendar and table type for easily review - Flexible Track Manager – On-Device created to User track, and QRacing Sync to Shared track - G-force meter to plot G-force status - Smart speedometer to show real-time speed information - Device configurable such as unit, backlight, brightness, time zone, or time format - Support On-Device Export to KML, CSV or GPX files Hardware: - Adopt MTK II chipset with high sensitivity -165dBm and 66-Channel tracking - 2.4 (320x240) TFT Color display with 65K color - Ultra lower power consumption up to 10hrs operation (under LCD backlight on) - Log rate up to 10Hz excellent for High speed Racing (1) - Including 8 Function buttons – 4 Direction Buttons (Up/Down/Left/Right) / Back, Enter, Mulit-function, and Power Buttons - 3 LED Indicators – Green for Screen Power Saving, Orange for Charging, and Red for Alert - Built-in G-sensor for G-force measurement and Auto Start trigger - Built-in 2GB large memory inside - Device recognized as USB removable disk for data access with computer conveniently - Raise beeper function to notice some status of device - IPX-3 water resistance - Less than 15-Sec. AGPS fix support to realize faster TTFF and positioning - under warm start - Mini-USB interface for charging, data download and firmware update - Firmware upgradable - Device Dimension (LxWxH): 100 x 59 x 28mm - Device Weight: 107 grams (Mounting bracket excluded) LT-Q6000 IPX-3 Water-resistance: https://www.evasivemotorsports.com/m...0001/QST-5.jpg LT-Q6000 Box Package: https://www.evasivemotorsports.com/m...0001/QST-7.jpg https://www.evasivemotorsports.com/m...0001/QST-9.jpg -------------------------------------------------------------------------------------------------- Payment Information Paypal Paypal Address – Sales@Evasivemotorsports.com Memo - #1 What you want to order #2 S2ki Member #3 Telephone number We will only take confirmed paypal accounts with verified shipping addresses Credit Card Please give me a call at the office (626.336.3400) for any credit card transaction. The billing and shipping address has to be the same unless your shipping address is an alternative address filed with your credit card company International If you are an international customers we only take wire transfer as a form of payment. Please PM me for wire transfer information 9.0% California tax applies if you are in California. Contact Information Evasive Motorsports - 626.336.3400 - Dennis@Evasivemotorsports.com Evasive Motorsports Website Evasive Motorsports Blog |
How does this compare to AiM SOLO? Can you PM pricing on this and AiM SOLO to 60076?
bump
:bump:
:thumbup: :thumbup:
Back in stock :thumbup:
Instock and ready to ship. :rev: Great way to keep track of your lap times.
:hello:
