Race Technology DL1 Data Loggers + Accessories
Former Sponsor
Race Technology Products are now available from Go Tuning Unlimited!
Free shipping on all products! Most items are in stock.
PM FOR S2Ki Special Sale Price!
Race Technology data loggers and displays have been extensively used and proven with many club racer and professional racers for accuracy and reliability. Data logging and live timing is crucial is for real-time improvements on track and off-track analysis for improving lap times. Race Technology software is also extremely easy to use and useful in analyzing collected data.
DL1 MK3 Data Logger with powerful live processing - MSRP $999
The DL1 MK3 data logger is a highly configurable and powerful logging instrument. Whether you want to do a few track days and analyse your data, or if you are professional racer looking to add logging and a configurable control system to your race car.
- Powerful onboard processing - perform calculations live. The results can be viewed live (on a display or video), not just in post analysis.
- Timeslip can be calculated live and displayed directly to the driver, showing exactly how much faster of slower you are continuously - not just at lap and sector markers.
- Sensor data is processed directly by the unit rather than having to be processed in the dashboard, VIDEO4 unit and Analysis software separately.
- User defined channels used to perform maths functions on the live data, e.g. combine 4 wheel speed sensors to show if the average speed of the front wheels is higher than the rear wheels, showing spin and braking lockup. This can be displayed live to the driver, overlaid onto a video, or logged for analysis.
- Review your braking points and overall grip with the built in 2g 3-axis accelerometer, optional 6g 3-axis accelerometer for high down force applications.
- Optional switched outputs for advanced control of vehicle options such as pumps and fans. The control can be simple or based on a complicated equation, e.g. turning on a cooling fan when temperature is high and speed is low.
- Up to 12 analogue (8 std) and 4 optional frequency inputs to connect sensors such as: wheel speeds, steering angle, damper pots, brake pressure, engine sensors, etc.
- Extensive automatic logging control, making sure exactly the required data is logged.
- Get the most out of your engine by logging information from your ECU*.
- Measure your drift angle with the gyro option.
- Unrivalled accuracy with the 20Hz GPS option (5Hz standard).
- USB port for reconfiguring and reflash
DL1 Data Logger - High Performance GPS Clubman Datalogger - MSRP $859
The DL1 is a highly flexible, powerful data logging system. Featuring an integrated, high accuracy, 5Hz GPS receiver, with data logging directly to compact flash. It is ideally suited to auto sport applications as well as bikes, boats and industrial/professional applications.
DL2 Data Logger - High End Professional GPS Datalogger System - MSRP $1990
The bigger brother of the DL1, and based on the same core technology, the DL2 has been enhanced for harsh environments and improved performance with a water-resistant machined aluminium case and 20Hz high-accuracy GPS system specifically designed for this application.
DASH3 Display unit - Compact Configurable Display - MSRP $299 (Dash3lite) / $418 (Dash3)
- The DASH3 is a data and lap time display that is designed to work with Race Technology's range of data logging products. It is the smallest display in the range and can be used to provide either supplementary information alongside other instruments, or as the primary source of information in some race applications.
- Physically, the DASH3 is housed in a small injection moulded case and is controlled by a sealed membrane keypad. The display is a custom made graphics panel which has been designed to be clear and readable from almost any angle and under any lighting conditions.
The DASH3 comes in 2 versions, the DASH3 and the DASH3lite:
- The DASH3lite is designed primarily as a lap time display, but also displays speed and has the configurable shift lights.
- The standard DASH3 has all the features of the DASH3lite, but in addition can be configured to display almost any combination of numerical displays, graphs and bar charts of any variable and also display warning etc. This makes it a very flexible solution to all of your data displaying needs.
DASH4 Pro - Compact Configurable OLED Display - MSRP $679
- The DASH4 PRO is part of the new PRO racing range of products. Featuring a sealed water proof aluminium body, high quality connectors and a compact profile, it is the ideal partner to match the DL1 PRO.
- The DASH4 PRO is designed for steering wheel mounting within all popular sizes of wheel, or alternatively it can be mounted to a flat panel or custom bracket.
The DASH4 PRO also features:
- The very latest "OLED" display technology. This has a high resolution, ultra wide viewing angle and wide operating temperature range. OLED gives incredible contrast in low light conditions.
- Display any combination of information, split over 5 pages - display ECU variables, speed, analogue inputs etc.
- Very comprehensive lap timing functions including live "time slip*" and predictive lap times.**
- Configure shift lights to display live time slip, see where you are faster or slower continuously, not just at lap and sector markers.*
- Displays text in small, medium or large text and also can be configured to display graphics, graphs and bar charts.
- Variable brightness, bi-colour dual shift lights.
- Built in performance testing functions to test brake and engine performance.
- Comprehensive alarms which can trigger when any input is out of range.
Additional accessories, add-ons, and upgrades available by request.
Visit http://www.race-technology.com for more information.
Shipping/Insurance Info:
- Shipping cost will be determined by location.
- Insurance will be included on all orders.
- Shipping to Canada, Hawaii, Alaska, or international. Please PM me for shipping quote.
- For local pick up please PM me. We are located in Orange County, CA.
- The product(s) will be very well packaged.
Payment Info:
- You can order by phone, email, PM, or through our website at gotuning.com
- We accept Visa, Mastercard, Discover, Paypal, Cash, Bank Cashier's Check.
- All order MUST be shipped to billing address or confirmed address for paypal.
- Paypal payments can be sent to paypal@gotuning.com.
- 7.75% Sales Tax sales tax is required for all sales within California.
Payment Info:
