Revel VLS OLED Gauges 52mm | Boost / Wideband & More *In Stock*
https://www.kamispeed.com/v/vspfiles...rers/Revel.jpg Hello all! We keep the new Revel VLS gauges in stock and ready to ship! These come with all the necessary sensors, mounting pods and everything to get it installed on your S2k. They are also daisy chain compatible!! The OLED lights provide a sharper image over the standard LED along with an undistorted viewing angle of around 170 degrees. These dont need any backlighting so they are designed slimmer so they fit in smaller places much easier than some other bulky gauges. REVEL VLS OLED 52MM BOOST GAUGE (30INHG - 45PSI) | $159.60 Reading : Boost Size : 52mm Boost : 30 inHG - 45 PSI https://www.kamispeed.com/v/vspfiles...1AA001R-2T.jpg https://www.kamispeed.com/v/vspfiles...1AA001R-3T.jpg REVEL VLS OLED GAUGE - 52MM OIL PRESSURE | $188.10 Reading : Oil Pressure Size : 52mm Pressure : 0 - 150 PSI https://www.kamispeed.com/v/vspfiles...1AA004R-2T.jpg REVEL VLS OLED 52 MM GAUGE - OIL TEMPERATURE | $140.60 Reading : Oil Temperature Size : 52mm Temperature : 100 - 300 Degrees Fahrenheit https://www.kamispeed.com/v/vspfiles...1AA003R-2T.jpg REVEL VLS OLED GAUGE - 52MM WIDEBAND A/F RATIO | $268.20 Reading : Air Fuel Ratio Size : 52mm AFR Reading : 10.0:1 ~ 20.0:1 Sensor : Bosch 4.9 LSU (included) https://www.kamispeed.com/v/vspfiles...1AA005R-2T.jpg REVEL VLS 52MM OLED GAUGE - WATER TEMPERATURE | $140.60 Reading : Water Temperature Size : 52mm Temperature : 100 - 300 Degrees Fahrenheit https://www.kamispeed.com/v/vspfiles...1AA002R-2T.jpg |
Bump!! |
