S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Sponsor S2000 Engine and S2000 Drivetrain Deals (https://www.s2ki.com/forums/sponsor-s2000-engine-s2000-drivetrain-deals-186/)
-   -   BALLADE SPORTS Heavy Duty Inboard CV Joint Assy. Kit (https://www.s2ki.com/forums/sponsor-s2000-engine-s2000-drivetrain-deals-186/ballade-sports-heavy-duty-inboard-cv-joint-assy-kit-975975/)
BalladeSports Aug 29, 2012 04:41 PM
Price: $200 per CV Joint.
Ballade Sports
13851 A Better Way #11D
Garden Grove, CA 92843
714-902-9027
www.balladesports.com
http://i272.photobucket.com/albums/j...IMAG2152-1.jpg
Fits all S2000 model years.
Ballade Sports Heavy Duty Inboard CV Joint assembly addresses the ongoing problem with bearing wear to the Inner CV Joints. This unit is CNC machined out of 8620 alloy forged steel and has been heat treated. The housing itself is a ONE piece design with a modified bearing track for reduced friction. The STD factory unit is originally a 2 piece design with an inertial weld. The internals of this product use the same style tripod roller bearing assembly as STD Honda, but features high performance needle bearings within each roller, unlike the STD Honda bearing. This unit is proven to last longer and reduce friction rotation than the OEM unit. The housing is larger in overall diameter increasing strength and uses HTS2 high temperature axle grease. The kit comes complete to rebuild one factory axle. Includes 1 CV Joint housing, 2 snap rings, 2 stainless steel clamps, 1 tripod roller bearing assy, 1 HTS2 grease tube, 1 CV boot.
http://i272.photobucket.com/albums/j...0/IMAG2159.jpg
http://i272.photobucket.com/albums/j...0/IMAG2160.jpg
http://i272.photobucket.com/albums/j...0/IMAG2153.jpg
http://i272.photobucket.com/albums/j...0/IMAG2154.jpg
http://i272.photobucket.com/albums/j...0/IMAG2158.jpg
http://i272.photobucket.com/albums/j...0/IMAG2157.jpg
http://i272.photobucket.com/albums/j...0/IMAG2156.jpg
Alex.Torch12 Jun 9, 2014 09:13 PM
i don't mean to sound stupid but what is the benefits of having a heavy duty inboard CV joint kit?
BalladeSports Jun 12, 2014 02:16 PM
^The photo showing the pitting in the inner CV cup from the STD unit causes vibration during acceleration in the S2000. Our CV cup assy kit is to replace the old factory units that have pitted and failed.
Fierc3 Apr 9, 2015 08:51 AM
I need this, when will it be back in stock??
JUSTINTHECOASTIE May 1, 2015 12:11 PM
x2
© 2026 MH Sub I, LLC dba Internet Brands
