Ballade Sports Now Stocking Radium Engineering Products.
Former Sponsor
We now offer and stock Radium Engineering Products. For pricing, please visit our website. If you have any questions please contact us by email, PM, or by phone.
Radium Engineering S2000 Catch Can Kit (00-05 LHD)
An oil catch can is essential on a performance vehicle to protect the engine from elevated levels of crankcase blow-by accumulated from aggressive driving. Excess oil saturated air circulating back into the air intake stream can lead to degraded performance.
Unlike many catch cans on the market, this catch can features an integrated oil separator that accelerates oil condensation. This cleans the PCV gasses and reduces the oil build-up on the inside of the intake tract and intake manifold. The stainless steel filtration media is cleanable and reusable.
Read about all the benefits and functionality of the Radium Engineering's popular catch cans here:
http://radiumauto.com/media/blog-pag...-Catch-Cans-25
Features:
-Effectively raises the octane and increased engine performance from cleaner inlet air
-Prevents oil buildup in the intake or intercooler system walls, throttle body, intake manifold, etc.
-Excessive oil collection can be an indicator of a damaged engine.
-Lowers hydrocarbon emissions
-Capacity: 6 fluid ounces
-Height (without fittings): 5 inches
-Outside Diameter: 2.45 inches
Crankcase Vent Kit Includes:
-Radium billet oil catch can with integrated condenser and dipstick
-Radium laser cut powder coated S2000 specific mounting bracket
-Anodized aluminum -8AN hose ends and adapter fittings
-Enough 1/2" PCV rubber hose to mate to custom applications
-Vacuum and heater hose to eliminate OEM metal hard tube loom
-Stainless steel mounting hardware
PCV Kit Includes:
-Anodized aluminum -6AN hose ends
-Anodized -6AN adapter fittings
-Honda OEM spring hose clamps
-3/8" PCV rubber hose
Radium Engineering S2000 Catch Can Kit (RHD/06-09 LHD)
Features:
-Radium S2000-specific laser cut powder coated mounting bracket
PCV Kit Includes:
-Radium universal laser cut powder coated mounting bracket
Radium Engineering Fuel Rail for S2000 (00-05)
This big bore fuel rail features a large 0.69" diameter internal bore with 3/4"-16 female threads (-8AN O-ring port) at each end to accept a variety of adapter fittings for custom high flow fuel system builds. This is the largest S2000 fuel rail bore on the market that uses all 5 crucial OEM mounting bosses. The fuel rail is machined, anodized, and laser etched for a high quality surface finish. It is compatible with all fuel types including popular alcohol mixtures such as E85.
It is directly compatible with the 2004-2005 (AP2) OEM fuel feed banjo hose. However, if the OEM banjo hose will be reused on the 2000-2003 (AP1) S2000, Honda P/N: 16623-PCX-003 must be purchased. This is a Joint, Fuel Flange found on the AP2 fuel rail (shown below) that prevents the banjo from spinning while the bolt is torqued. Also, note the restrictive 0.21" (5.3mm) orifice of the OEM banjo flange. This fuel rail was not designed for the 06-09 Honda S2000.
Alternatively, a block-off plate with stainless steel hardware and O-ring is included if the OEM hose is to be replaced with a high flow hose.
This kit eliminates the OEM fuel rail cover and also replaces the air pump system hard tubes with vacuum hose for a cleaner appearance.
OPTIONS:
20-0091-00 Fuel Rail Kit, For Stock Fuel Line
This option includes everything required to simply unbolt and replace the OEM fuel rail. Replacement vacuum tubing is included to simplify and eliminate the hard lines. Also, included is extra -6AN and -8AN male adapter fittings for plumbing custom high powered applications.
Includes:
-6AN male adapter fitting
-3/4-16" plug (x2)
-Banjo block-off plate w/ O-ring
-Vacuum Tubing
-Stainless steel hardware
20-0091-01 Fuel Rail Kit, PTFE Hose Included
This option includes everything from the 20-0091-00 fuel rail kit with the addition of a -6AN PTFE hose connection to replace the restrictive OEM banjo fitting and a special inverted flare adapter fitting that connects to the OEM hard line near the firewall. The 41" high quality PTFE hose is compatible with E85, ethanol, alcohol, gasoline, etc. The included billet block-off plate will be used to cap the stock banjo feed port.
Radium Engineering Universal Single Catch Can
An oil catch can is essential on a performance vehicle to protect the engine from elevated levels of crankcase blow-by accumulated from aggressive driving. Excess oil saturated air circulating back into the air intake stream can lead to degraded performance. Unlike many catch cans on the market, this catch can features an integrated oil separator that accelerates oil condensation. This stainless steel filter media is cleanable and reusable.
The liquid oil is then collected in the reservoir. The fluid can be easily disposed without removing the can from its bracket. The lower half of the body simply unscrews for draining or the bottom port can be used with the RADIUM Petcock Drain Kit if the cans cannot be easily separated. The integrated dipstick unscrews for a quick way to check oil level.
Note: Some engines may require multiple catch cans depending on the PCV system design.
Benefits:
-Effectively raises octane and increases engine performance with cleaner inlet air
-Prevents oil buildup in the intake, intercooler, throttle body, etc.
Features:
-6061 Billet Aluminum O-Ring Sealed Oil Can
-Integrated Oil Separating Condensing
-Stainless Steel Cleanable and Reusable Filter Media
-Main Ports: 7/8"-14 Female Threads (-10AN O-Ring)
-Powder Coated Laser Cut Mounting Bracket
-O-Ring Sealed -4AN Drain Plug
-Stainless Steel Mounting Hardware
-Safe for Pressurized Applications
-Anodized 6061 Billet Aluminum Oil Dipstick
Dimensions:
-Capacity: 6 fluid ounces -Height (without fittings): 5 inches
Options:
Petcock Drain Kit
-Anodized Aluminum -4AN O-Ring Barbed Fitting
-Nylon ¼” Barb Mini Ball Valve
-6ft High Temperature Rubber Hose
Features:
PCV Kit Includes:
Features:
PCV Kit Includes:
OPTIONS:
Includes:
-3/4-16" plug (x2)
-Vacuum Tubing
Benefits:
Features:
Dimensions:
Options:
Petcock Drain Kit
A 2
07-30-2010 04:38 PM
