Ballade Sports Valve Spring Kit 00-09
Former Sponsor
Ballade Sports 00-09 Honda S2000 Valve Spring Kit
Ballade Sports S2000 Valve Spring Set provides maximum lift while preventing valve float and helps counter the effects of spring surge. These have been track tested under harsh road race conditions. The increased spring rate help reduce valve guide wear and piston to valve contact. These are perfect solution for naturally-aspirated applications using OEM AP1/AP2 retainers and spring bases! These are direct fit replacement. No additional parts required for installation.
Track tested and ready to ship!
Technical information:
TYPE: Single Spring
OUTSPR.OD: 31.6mm
OUTSPR.ID: 22.7mm
PRESS.SEAT: 95 @ 40.4
PRESS.OPEN: 253 @ 12
MAX LIFT: 17.70mm
COIL BIND: 22.7mm
RATE: 13.2mm
TYPE: Single Spring
OUTSPR.OD: 31.6mm
OUTSPR.ID: 22.7mm
MAX LIFT: 17.70mm
COIL BIND: 22.7mm
RATE: 13.2mm
