Berk Technology Product for S2000! MVP Motorsports
HPC Coated Header
Thermal barrier coated using High Performance Coatings (HPC) Hipercoat 1600+ process on the inside and outside of the header. The Hipercoat process helps maintain high exhaust gas velocity which is key in header design and ultimate power production. One of the few 304 stainless & inside/outside ceramic coated headers in the world. Uses large port 50mm primaries & high flow CAD designed 63.5mm collector (2.5"). Perfect compliment to the Berk Technology 2.5" test pipe. Includes secondary wideband O2 sensor port for fuel tuning. One of the best performing headers for the AP1 & AP2 S2000 at any price.
Test Pipes - Available in 70mm and 63.5mm
High Flow Cats - Available in 70mm and 63.5mm
Featuring Magnaflow's new metallic substrate core. Less weight, more durability, and higher flow than your standard ceramic subsrtrate "high flow cat". Do not confuse these with cheap Chinese made ceramic substrate versions! These are very high quality parts made proudly in the USA by our expert fabricators.
Our test data shows that this cat flows 87% as well as a test pipe vs. 43% for the OEM Cat. Smog legal, high flow, no test pipe smell. You can have the best of both worlds. Includes new 3 bolt gasket & nuts/bolts.
Exhaust System Options:
3" Header back for AP1 AND AP2!!! - Includes Test Pipe
3" Header back for AP1 AND AP2!!! - Includes HFC
PM OR POST UP FOR S2KI SPECIAL PRICING!!!!
Regards,
Robert
