Cleib 70mm Exhaust System
#43
https://www.s2ki.com/forums/sale-247...xhaust-851011/
https://www.s2ki.com/forums/member-s...-cheap-757104/
#44
Just had this installed in a 2008 Type S (Asian CR), my stock exhaust had the rectangular helmholtz and I didn't have a problem with fitting the 70mm cleib. As for sound, I installed this along with an EVS tuning 70mm HFC and it is quite loud. This was expected as most 70mm single exits are pretty loud, but the exhaust sounds great I'd say and the sound level would sit between a EVS 70mm and a Js 70 RS. There is some drone at lower RPMs under load but it's tolerable, and cruising at certain speeds the exhaust is actually quite quiet. I haven't put a lot of miles on the exhaust but I'm liking it so far. The exhaust tip looks good with the AP2 bumper, just the right size without looking obnoxious like most single exit exhaust.
#45
#46
I have sat in a car with a J's 70 rs a handful of times and I would say the J's are slightly louder on the low end. I can't really give you a detailed comparison because I haven't owned a 70RS. If you're looking for a quieter exhaust, I would recommend getting the ASM single or just go for a double exit exhaust. The Cleib has a throaty pop and gurgle occasionally on deceleration, not sure if this is present in other exhausts but it makes me giggle like a little kid.
clubmagicdrive (05-31-2017)
#49
Member
Spotter
Spotter
