Fully caged sprung hub Clutchmasters clutch kit. Better and cheaper than OEM!
Ever blown up an Exedy OEM replacement or similar? It's no fun. The problem is the wimpy little cage that just can't hold up to the use that many S2ks see on track and on the street. The baskets will crack and inevitably fail, the springs will pop out, and you won't be able to disengage the clutch. This just happened to two of our local s2000 guys at Gingerman Raceway, but we've seen this happen on street driven cars as well.
Well check out this FULLY caged spurng hub disk. It's even beefier than the OEM honda disc. No chance of breaking these.
OEM for reference:
This kit comes with throwout bearing, pilot bearing, alignment tool. All are from OEM suppliers. It comes with the disk and the pressure plate as well. We can skin the disk in your choice of material. The pressure plate is very slightly heavier than the OEM pressure plate but lighter than the crowd favorite ACT HD. The full face disk makes it easy to live with for daily driving. But there's plenty of clamping force for spirited track use. The pressure plate is also built with reducing wear on the thrust washers in mind.
We can get you a flywheel to go with it too. Sure AP1 flywheels are great. But if you're looking at spending $100 to get a flywheel, and then another $75-125 to get it machined, you're most of the way to a new flywheels anyways.
This is an exclusive kit I've put together with Clutchmasters and have been running it in several of our track cars without issues. And it's FAR cheaper than trying to piece-meal together an OEM disk, bearings, and ACT HD pressure plate.
As far as pressure plate clamping force:
OEM has about 1870lb of clamp force
SPEC is about 2100.
Clutch Masters is about 2400 and does not result in a stiff or difficult to drive clutch.
ACT is 2500-2600 though we have found some variance. And the resulting pedal is a fair bit firmer than the Clutch Masters PP.
Bump for Labor Day sale pricing! Sitewide savings. But special pricing on this clutch for anybody willing to write a review, good or bad (but I think you'll have good things to say).
