Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
Fumoto Oil Drain Valve - Easiest oil change ever!
Old 06-21-2009, 10:39 PM
Sponsor
JS2k.com's Avatar
Wink Fumoto Oil Drain Valve - Easiest oil change ever!
Now taking PreOrders for the Oil Drain Valve
Please see this thread: https://www.s2ki.com/forums/index.php?showtopic=811819
__________________________________________________ _________________
New Promo:
Buy both Oil Drain Valve and my Keyhole Covers, and get $2 off your total order! Please use the code '2off2' during checkout. For those who have ordered before this coupon, PM me and I'll send you back $2.
Community Organizers and local Group Buys: Contact me for a discount on multiple orders
Introducing the easiest way to change your oil with no need for tools or jacking up your car!
Just watch the video below to see how easy your oil changes will be.
Our Oil Drain Valves make oil changes so much simpler. Install this valve instead of your drain bolt to drain your oil with no hassle and never a worry of a frozen or stripped drain bolt. These valves are double sealed to prevent leakage and years of service. With its forged brass and stainless steel composition, it resists corrosion from the water and mud that it may be exposed to. The lever locks to prevent accidental opening of the valve.
For some vehicles, like the S2000, you will never need to jack up the car to do an oil change again! Just slide a drain pan under the car and release the lever! This makes oil changes so easy, you can finally do oil changes without a garage or in the dead of winter! Save hundreds of dollars in labor for a simple task.
Oil changes demonstration with our Oil Drain Valve
[media]http://www.youtube.com/watch?v=gVmq8-obCEc [/media]
This video shows how easy it is to do an oil change after installing our Oil Drain Valve. Even my girlfriend Mina can do it with ease!
Installation
Steps for installation:
1. Remove OEM drain plug
2. Let oil drain
3. Screw in the Oil Drain Valve with provided washer
4. Do not overtorque the Oil Drain Valve.
Steps to ensure you do not overtorque the Oil Drain Valve and break the threads
1. Thread the valve to the adapter by hand as tight as possible.
2. Use and adjustable wrench to turn it not more than a quarter of a turn more
3. Thread the adapter and valve into the oil pan by hand as tight as possible
4. Again, use the adjustable wrench to turn it just a bit more. Probably not even a quarter of a turn.
Steps for an oil change after Oil Drain Valve has been installed
1. Open hood
2. Place oil drain pan under oil pan
3. Unscrew oil filter
4. Open the Oil Drain Valve
5. Screw in new filter
6. Close the Oil Drain Valve
7. Add oil
Oil Drain Pan used
Autozone carries an oil drain pan that will fit under S2000s lowered 2 inches as shown in the video.
It costs about $2: Link here. The drain pan measures 3.5" in height.
Cost:
$29.99 for the Valve and required adapter
Click here for more information
Click here to order.
FAQ
Q. How much does the Engine Oil Drain Valve stick out from the oil pan?
A. S2000s equipped with the Oil Drain Valves need not worry about ground clearance, as the valve extends parallel to the ground. If your oil pan does not scrape, then valve will not. In fact, many points of the frame are lower than the oil pan or the valve.
Q: Do you have them for other applications?
A: I do have applicatoins for most Hondas. I may also be able to get them for other vehicles. Please reply or PM me.
Q: What do other people think about this valve?
A: https://www.s2ki.com/forums/index.ph...ic=730641&st=0
Check out my other products!
Miniature S2000 Keychains!
S2000 OEM Color Matched Keyhole Covers
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
JS2k.com is online now
Old 06-21-2009, 11:35 PM
9K-S2K's Avatar
Cool drain valve. I may consider picking one up...
9K-S2K is offline
Old 06-22-2009, 05:44 AM
TheDarkKnight's Avatar
nice
TheDarkKnight is offline
Old 06-22-2009, 05:51 AM
danvuquoc's Avatar
I have one it's very convenient, especially if you have a CAI.
danvuquoc is offline
Old 06-22-2009, 08:57 AM
Sponsor
JS2k.com's Avatar
Thanks guys, orders placed today before 5:30 will be shipped out same day.
__________________
_________
Old 06-22-2009, 11:04 AM
fastD's Avatar
Bummer, I signed up and was going to order when I noticed there are 0 in stock.....and the web site says sold out.
fastD is offline
Old 06-22-2009, 01:14 PM
Sponsor
JS2k.com's Avatar
FastD: is it for your TL? Or am S2000? I am on my way to pick up more valves and will see if they have more. I cleaned out their stock last time.
__________________
_________
Old 06-22-2009, 05:18 PM
gtg749m's Avatar
i bought one about 3 years ago, not from sponsor, but it was definately worth every penny. free bump on great product.
gtg749m is offline
Old 06-22-2009, 09:08 PM
PersianSTud's Avatar
Is she included ?
PersianSTud is offline
Old 06-23-2009, 05:40 AM
Sponsor
JS2k.com's Avatar
nope.
__________________
_________
Quick Reply: Fumoto Oil Drain Valve - Easiest oil change ever!
