Radium Engineering Catch Cans, Big Bore Fuel Rail, Radiator Caps!
Radium Engineering is now available at RockStar Garage!
Since 2010, Radium Engineering's goal has been to simply design and produce the highest quality, best performing aftermarket automotive performance products. Located in the Pacific Northwest, Radium is a team with personal passions for innovation which leads Radium towards advancement in the industry.
CATCH CANS:
Radium Engineering offers two completely independent S2000 oil catch can kits that are sold individually or together. They do NOT vent to atmosphere (VTA), thus are emissions and track legal. Closed loop systems route clean filtered air back in through the engine to be burned and to promote negative crankcase pressure for optimal performance. Furthermore, closed systems prevent unwanted oil vapors into the cabin.
Features:
-Effectively raises the octane and increased engine performance from cleaner inlet air
-Prevents oil buildup in the intake or intercooler system walls, throttle body, intake manifold, etc.
-Excessive oil collection can be an indicator of a damaged engine.
-Lowers hydrocarbon emissions
-Capacity: 6 fluid ounces
-Height (without fittings): 5 inches
-Outside Diameter: 2.45 inches
00-05 S2000
PCV Catch Can Kit - $227
Crankcase Catch Can Kit - $241
Dual Catch Can Combo ( PCV and Crankcase) - $426
06-09 S2000
PCV Catch Can Kit - $241
Dual Catch Can Kit - $426
FUEL RAIL:
The Radium Engineering big bore fuel rail for S2000 features a large 0.69" diameter internal bore with 3/4"-16 female threads (-8AN O-ring port) at each end to accept a variety of adapter fittings for custom high flow fuel system builds. This is the largest S2000 fuel rail bore on the market that uses all 5 crucial OEM mounting bosses. The fuel rail is machined, anodized, and laser etched for a high quality surface finish. It is compatible with all fuel types including popular alcohol mixtures such as E85.
Fuel Rail Kit, S2000, 2000-2005 - $132
Includes:
-Billet anodized aluminum fuel rail
-Banjo block-off plate w/ O-ring
-Vacuum tubing
-Stainless steel hardware
Fuel Rail Kit, S2000, 2000-2005, PTFE Hose Included - $208
Includes:
-Vacuum tubing
-Fittings for all 3 ports
-23” 6AN PTFE Hose
-M14 inverted flare to -6AN fitting(converts OE hardline to -6AN)
Optional:
Fuel Pressure Gauge - $51
Fuel Pulse Damper - FPD-R, 8AN ORB - $84
Fuel Pulse Damper - FPD-XR, 8AN ORB - $94
Radiator Cap:
Radium Radiator Cap, Type-B, 1.1Bar,16.0psi -$29.95
Radium Radiator Cap, Type-B, 1.3Bar,18.9psi -$29.95
Radium Radiator Cap, Type-B, 1.5Bar,21.8psi -$29.95
Purchase with confidence! RockStar Garage is a direct authorized dealer with Radium Engineering.
We are really liking the Radium on our race car! We are running the dual catch can set up as well as the fuel rail with PTFE line, fuel pulse damper, and pressure gauge.
