URGE Scavenger System Updates! Now V2 Exhaust
6 Attachment(s)
43 Scavenger Mid Pipes Sold!!
OEM Motor; Gern Pipe vs Test Pipe vs Stock http://urgedesigns.com/wp-content/up...r-graph_01.jpg 260+ WHP 2.3L Built Motor; Gern Pipe Full Tune vs Gern Pipe Quick Tune vs Berk 70mm HFC Full Tune http://urgedesigns.com/wp-content/up...-wp-graph1.jpg Gern Pipe $1200
Reserved for Commitments and Order Times
1. AD, URGE Spec Gern Pipe & T1R Dual 2. ST, STR Spec Gern Pipe & T1R Dual 3. BeeB, URGE Spec Gern Pipe & T1R Dual 4. Conedodger, STR Spec Gern Pipe & T1R Dual 5. Korinfox, STR Spec Gern Pipe & T1R Single 6. z2theander, URGE Spec Gern Pipe & T1R Dual 7. Topplayer, URGE Spec Gern Pipe & T1R Single 8. MK, STR Spec Gern Pipe & T1R Single 9. neurotic, STR Spec Gern Pipe & T1R Single 10. sillyboybmxer, STR Spec Gern Pipe & T1R Single 11. RS, STR & Gernby Spec Gern Pipe 12. OB, URGE Spec Gern Pipe & T1R Dual 13. thepoi, Gernby Spec Gern Pipe 14. jaboo008, URGE Spec Gern Pipe & T1R Dual 15. SHG_James, URGE Spec Gern Pipe & T1R Single 16. S4Speed, URGE Spec Gern Pipe & T1R Dual 17. JE, URGE Spec Gern Pipe & T1R Dual 18. JeremyClarkson, URGE Spec Gern Pipe & T1R Dual First Batch Order Cut off Next 10 or August 15th is the next batch 19. SA, URGE Spec Gernpipe & T1R Dual 20. ericg, URGE Spec Gernpipe & T1R Single 21. PE, URGE Spec Gernpipe & T1R Dual 22. s2sik, URGE Spec Gernpipe & T1R Single 23. Fongu, URGE Spec Gernpipe & T1R Single 24. MS, URGE Spec Gernpipe & T1R Single 25. MK, URGE Spec Gernpipe & T1R Dual 26. DA, URGE Spec Gernpipe & T1R Dual 27. DW, URGE Spec Gernpipe & T1R Single 28. AK, URGE Spec Gernpipe & T1R Dual 29. BG, URGE Spec Gernpipe & T1R Single |
Reserved for Common Questions
I replied to your email Patrick, add me to the list. Thanks!
Are there any pics available for option #3? I am looking to connect the rear muffler section of my Invidia Q300 to it
Originally Posted by Yuen
(Post 23677558)
Been waiting for this!
So happy Urge exists.
If you can post up db readings I would be in for sure. Also there was some talk about the hfc not doing well with Forced induction, is that true in any way?
Originally Posted by SHG_James
(Post 23677617)
Originally Posted by Kilomph
(Post 23677695)
Originally Posted by michaelnyden
(Post 23677696)
One HFC did get loose out of one of Gernby's original 50. We can provide a new cat for $100 and it would cost a few $100 to re weld back in. For less than $300 it can be replaced. Any Forced Induction Car running rich will burn up any cat, OEM, Heavy Metal, etc. |
