*Buddyclub N+/RSD* Espelir springs
Sponsor
Buddyclub N+ coilovers
Mono-Tube type shell case
Height Adjustability w/ High Quality Aluminum Perches
15 Way Adjustable Dampening
Pillow Ball Upper Mounts
Exclusive Buddy Club Springs
PM for Price
Apex-i EXV Coilovers
44mm Shock Piston
Incorporates the same N1 Damper Series high precision valve and piston for acurate settings
32 Way Ride Adjustment
Compression and Spring rates specially matched for US road conditions
The Quick Adjuster allows for easy compression ratio adjustment
PM for price
Espelir ASD springs...Back in stock. Best price anywhere for these. Best Price anywhere. Find someone else that has these cheaper and we will beat their price.
Espelir ASD Springs
Lowers:
f- 20mm
r- 30mm
PM for price. Taking Pre-Orders now
Eibach Pro Kit
Lowers:
f- 1"
r- 1"
$249 Shipped
Tanabe GF210
Lowers:
f- .8"
r- .8"
$195 Shipped
Swift Sport Springs
Lowers:
f- .8"
r- .8"
$375 Shipped
Ohlins DFV Coilovers
The new �hlins suspension for Honda S2000 is suited for both street and race cars. The shock absorbers and settings are developed on both ordinary streets and race tracks together with �hlins test drivers.
Key features:
� Type 46UR. based on the design of the MCJ racing shock
� Light weight aluminium body.
� Large reservoir integrated in the cylinder tube for better cooling.
� External adjustable rebound
� Quick response for best handling.
� Optimum consistency on long runs.
� Easy to dial-in, reshim, rebuild and service.
� In addition to the main piston there is also an integrated compression valve, called the base plate or base valve.
� Professional technical support.
Spring Rates:
Front - 10kg/mm, Rear - 8kg/mm.
$PM For Price
KW V3 Coilovers
The new KW Variant 3 coilovers are state-of-the-art coilovers designed specifically for the skilled and experienced driver. These coilovers are perfect for heavy track use and are used competitively world-wide. The separate and independent compression and rebound damping options allow for suspension fine-tuning. The unique triple-adjustable components, allow for low-speed compression adjustment, while the high-speed compression has been preset by KW engineers. The end result is a high quality ride with track-ready performance.
Features
� Independently adjustable damping technology -rebound and compression damping
� Inox-line stainless steel technology at no extra charge
� Individual height adjustment
� German TUEV-tested adjustment parameters
� High-quality components for long life
� Comprehensive documentation for ease of use
� Infinitely adjustable rebound damping
� 14- level adjustable compression damping
� Unique, independently functioning damping power adjustment
$PM For Price.
If you find a lower quote from an authorized KW dealer, I will match it and throw in a free pair of Oakely sunglasses.
HKS Hipermax 3 Sport Coilovers
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
� Hiper Linear Piston � Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
� Pillowball upper mounts standard
� Monotube design
� Shock-body length adjustable (most applications)
� 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
� Lightweight Aluminum lock nut & ride height adjuster
� Hard chrome-plated cylinder shaft
� Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
� Dustboots standard
� 1 year limited warranty
$1799 shipped
SPC Camber Kit
Designed specifically for the S2000, this ball joint corrects camber on both the front and rear. An OE quality ball joint, this adjustable part corrects camber up to �3.0 degree.
NOTE: The rear applications are ONLY for vehicles equipped with 17" rims or larger. Front applications work with all stock rim sizes and larger.
Front/Rear* Adjustment range: Camber -3.00 degree to +3.00 degree
Installation Time: .6 hr/side
Required: 1 per wheel
APPLICATIONS
Honda: 2000 & Up S2000
*Caution: Rear application for vehicles with 17" rims or larger.
Front and Rear Kit
$375 Shipped
Whiteline Sway Bars
Super Lightweight
30mm Front
$PM For Price
30mm Rear
$Pm For Price
Front and Rear 30mm Kit
$375 Shipped
Whiteline X-Brace
$259 Shipped
*Fits with aftermarket swaybars
*Does not interfere with oil changes
PM for Price
44mm Shock Piston
PM for price
Espelir ASD Springs
Lowers:
f- 20mm
r- 30mm
Eibach Pro Kit
Lowers:
f- 1"
r- 1"
$249 Shipped
Tanabe GF210
Lowers:
f- .8"
r- .8"
$195 Shipped
Swift Sport Springs
Lowers:
f- .8"
r- .8"
$375 Shipped
Key features:
Spring Rates:
$PM For Price
KW V3 Coilovers
Features
$PM For Price.
Key Features:
� Monotube design
$1799 shipped
SPC Camber Kit
APPLICATIONS
Front and Rear Kit
$375 Shipped
Whiteline Sway Bars
Super Lightweight
30mm Front
$PM For Price
30mm Rear
$Pm For Price
$375 Shipped
Whiteline X-Brace
$259 Shipped
__________________
- All Items Are Shipped Via FedEx.
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit.
- Any Order Cancellation Will Result In A 25% Processing Fee.
- Local Pick-Ups Available. Please Call For Details.
- No Cancellation on JDM Or Special Orders. No Exceptions!
Sponsor
Just to let you guys know HKS and KW will be raising their prices in January 2009.
Call now to get 2008 prices!
__________________
Sponsor
^^ PM sent
__________________
Sponsor
^^ PM sent
__________________
Sponsor
Bump
__________________
