CHALLENGE - Comp Plus and Comp Coilovers - back in stock! - S2KI SPECIAL
Former Sponsor
Challenge Mfg. USA, our product development and engineering arm of GT Motoring has finally made more coilovers available for our customers for the summer of 2011. Developed by Challenge and Modex A, Buddy Club Japan's parent company and Japanese exclusive suspension facility. Through this partnership we have been able to bring you Japanese level suspension at a reasonable price for our customers. We wet out to develop these systems back in 2009 and have since racked up multiple Time Attack wins and Championships as well as numerous NASA TT wins by GT Motoring's Time Attack program as well as out dedicated customers that have been using our suspensions on and off the circuit.
For The 2011 season, we are bringing a revised Comp model that has a slighly lower price, and now features lightweight aluminum lower mounts in place of steel found in previous models. Also, slightly less aggressive spring rates are used for the best in all around street and circuit comfort.
Independant Review:
https://www.s2ki.com/s2000/topic/742...ilover-review/
This driver currently sits in first place in NASA midwest TTC class with his s2000 on Challenge Coilovers! Congrats David!
COMP Plus
Developed with ultimate track performance in mind, the COMP + damper kit is a complete coilover suspension solution. The kit features mono-tube, aluminum 16 level adjustable dampers that adjust rebound and compression simultaneously. Each kit includes full pillow ball upper mounts with aluminum mounting plates for optimal suspension response and durability. Damper bases are machined aluminum with a gloss black anodized finish. This damper kit sees about a 50% weight reduction when compared to the Comp model. The aluminum damper also aids in efficient damper performance and heat dissipation while on track. Top quality Hyperco 60mm racing coil springs in front and rear are our OEM spec. Custom spring rates are available per customer request at no additional charge.
Standard Recomended spring rates:
Front: 700 lbs/in
Rear: 700 lbs/in
Available in +/- 100 lbs/in springs with supplied valving
MSRP: $1895
S2KI Special: $1795 + free shipping
- Please PM or email for purchases or questions: greg@gtmotoring.com
COMP
Developed for both track and street driving, the COMP damper kit is a complete coilover suspension solution. The kit features mono-tube, steel, 16 level adjustable dampers that adjust rebound and compression simultaneously. Each kit includes full pillow ball upper mounts with aluminum mounting plates for optimal suspension response and durability. Damper bases are machined aluminum with a gloss black anodized finish. Top quality Hyperco 60mm racing coil springs in front and rear are our OEM spec. Custom spring rates are available per customer request at no additional charge.
Front: 450 lbs/in
Rear: 450 lbs/in
Available in + 100 lbs/in springs with supplied valving
MSRP: $1395
S2KI Special: $1295 + free shipping
Independant Review:
COMP Plus
Front: 700 lbs/in
Rear: 700 lbs/in
MSRP: $1895
COMP
Front: 450 lbs/in
Rear: 450 lbs/in
MSRP: $1395
Gorgeous! Good to see you have these back on the market.
Former Sponsor
Site Moderator
Absolutely love mine
Massive thanks to Greg for installing mine yesterday. I owe you one.
Former Sponsor
the new comp model looks like the comp+ but diff color and valved for lower rates.
cant wait to get my comp+ on. although I might need new rear lower ball joints ... sigh more money to spend.
Former Sponsor
Sorry to hear on the ball joints
