High Air Flow, Lightweight, 2-Piece Front & Rear Brake Rotor Upgrades
Sponsor
URGE designs Flow rear rotors $800 + Optional (customer can DIY) bracket modification $100
Girodisc 2 piece front rotors $800
Combine URGE Flow rear rotors with Girodisc front rotors for comparable brake improvement of a front BBK with stock rear rotors
(Ask about combo discount)
- 2 piece vented rear rotor vs solid OEM rear rotor
- Significant reduction in rear brake temps, eliminate rear bearing failures
- Customer proven over 170 degrees F after cool down lap, significantly cooler on track
- Customer proven to reduce front brake temps as rears don't fade, maintain consistent brake force (Front BBK 40 degrees F after a cool down lap, much cooler on track)
- Saves ~4 lbs total weight; ~2 lbs per rotor
- Must modify rear brake brackets or purchase URGE modified brake brackets
- Read full story on our website
- 2 piece curved vanes rotors vs OEM straight vaned rotors
- Curved vanes increase centrifugal effect pulling more air through the rotor
- Additionally curved vanes have more internal surface area increasing heat dissipation over OEM
- 30 vane rotors vs 24 for OEM also increasing air flow and surface area for heat dissipation vs OEM
- 2 piece rotors eliminate cracked rotors common to S2000 OEM and aftermarket 1 piece rotors due to lack of flexibility when overheated
- Reduce maintenance cost with longer pad life reduction due to lower temperature and in premature disc failure
- URGE Flow rears dramatically reduce rear brake temps AND moderately reduce front brake temps vs OEM solid rear rotors
- Girodisc fronts additionally reduce front brake temps vs OEM
- Upgrading both rotors have a compounding reduction in front brake temps
- Keep OEM shape pads front and rear
Last edited by Urge; 12-11-2022 at 08:18 AM. Reason: Poster asked for more specific title
only 2 posts, did you guys end up purchasing? Would like to see a write up.
