SakeBomb Garage | Custom FPSpört Ohlins DFV Group Buy
We are proud to introduce our new FPSpört Suspension Kit for the S2000! We developed this kit as an alternative to revalving the standard S2000 DFVs, and features an optimized valving curve, specially selected 11kg/mm front and rear spring rates, as well as custom billet aluminum lower mounting forks and billet aluminum top hats.
This is the Ultimate Street/Track crossover kit, ideally tuned for the S2000 with pricing which saves hundreds of dollars over a revalved DFV kit with replacement Springs.
Our Special Introductory Price is available only for a this initial production run, while supplies last!
For More Information and Purchasing, visit our product page: FPSpört Öhlins DFV (S2000) - SakeBomb Garage LLC
Excerpt from our Product Page:
Since its introduction, the Öhlins DFV line has revolutionized coilovers, and as a result, no longer are customers forced to choose between performance and ride quality. The Öhlins DFV valving design made it possible to have a truly track worthy damper that was also not only livable, but actually comfortable on the street, without sacrifice to performance driving. As suspension engineers, the one thing that always frustrated us was being forced into the mold of a standard off the shelf suspension settings. The vast majority of our Ohlins customers ultimately decide to purchase new springs for their DFVs, and we designed this SBG Exclusive suspension kit around the most popular settings amongst our customers, and included optimized valving to accept a wide range of performance street and track worthy spring rates. We include stronger and lighter aluminum lower mounting forks and custom top hats with teflon lines spherical bearings. The optimized valving curves offer much improved ride quality over the standard DFV kit, and elevated performance out of the box. For roughly the cost of a DFV kit and replacement springs, this kit is a no-brainer for any S2000 driver!
Product Features:
- Custom Spec 11kg/mm Front 11kg/mm Rear Springs Included
- Custom Valving - Offers greatly improved handling and comfort over the standard DFV kit while providing wide spring rate options
- Custom Billet 6061 Aluminum Lower Mounting Forks (stronger and lighter)
- Custom Billet 6061 Aluminum Top Hats with Spherical Bearings
Optimized Springs and Valving
While no two drivers or cars are the same, the vast majority of our customers choose to max out the the standard Ohlins valving on their DFV kits with custom spring rates. The FPSport kit utilizes custom valving designed for our higher square-spring-rate setup, with 11kg/mm front 11kg/mm rear springs. The result is an overall improvement in both traction and ride quality, with the ability to swap springs in a wider and more useable range without revalving (down to 9kg/mm and able to push 13-14kg/mm for track use). Geared towards square tire setups, we built this kit around s2000's prepped for performance as opposed to an s2000 with stock sway bars and tires. The valving curve is carefully balanced for comfort and performance driving, making this kit some of the best crossover use suspension available in this price range. We've increased the spring rate range that the valving can handle in order to allow more aggressive track oriented rates to be used (without the need for a re-valve), all without sacrificing comfort. At a cost comparable to a standard DFV kit with replacement springs, we feel that this setup hits a sweet spot for a modified s2000!
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
LudEcrous (04-26-2017)
As a bonus for our introductory release of the FPSpört Ohlins Coilover Kit, we are including our Custom SBG Designed Rear Remote Adjusters, which will allow you to keep your interior and have full control over your damper settings.
Introductory Pricing of $2295 is available on our website and adjusters are automatically included.
__________________
SakeBomb Garage (04-25-2017)
SakeBomb Garage (04-29-2017)
Yes, the listed price is the introductory group buy pricing. We'll update with an official list today but since launch we've sold 1/2 of the total 10 kits available. (The introductory group buy price is $100 off and includes the remote damper adjusters!)
__________________
We currently are wrapping up production and are aiming to begin shipping kits late next week!
Updated Pre-Order List:
1. FPSport - DE 19805 - Paid
2. FPSport - FL - PAID
3. FPSport - CA Pickup - Paid
4. FPSport - CA 95018 - Paid
5. FPSport - IL 60056 - Paid
6. FPSport - OR 97006 - Paid
7.
8.
9.
10.
---CLOSED
7.
8.
9.
10.
---CLOSED
__________________
LudEcrous (04-28-2017)
We were able to achieve the same stroke as the standard kit in a shorter damper body, This kit will be able to get about an inch lower than the standard DFV kit which eliminates the need for the low profile fork for the vast majority of use cases.
The whole point of this kit's design is to get all the common requests for upgrades built in, while maintaining a very reasonable price. With this kit, our goal was to achieve the same function of a standard kit + low profile rear fork & 4 swifts for significantly less than buying them piecemeal.
__________________
