SakeBomb Garage | FPSpec Remote Damper Adjusters Group Buy!
Our Special Introductory Price is $145 per set for the first 25 kits!
For More Information and Purchasing, visit our product page: FPSpëc Öhlins DFV Remote Damper Adjusters - SakeBomb Garage LLC
Excerpt from our Product Page:
Do you have Ohlins? Do you have an interior? Hate adjusting your rear damper through the gas filler accordion? Perfect, we've solved your damper adjustment problem once and for all. For years we've been frustrated with choosing between being able to adjust our suspension and have an OEM interior fitted. To solve this dilemma we've engineered a seamless remote adjuster solution which allows panel a remote extension cable and knob. Common sense? We thought so.
Features:
Adjust Your Dampers + Keep Your Interior!
Interfaces directly with standard Ohlins DFV gold adjusters
Custom Machined All-Aluminum Construction - anodized to match Ohlins
High-Quality Adjuster Cable - with aluminum crimp ends, inside low-friction PTFE tube
Fine Tactile-Feedback - high-flexibility cable with low-friction tubing lets you feel every click as if you were adjusting directly at the damper
Engineered and Manufactured by SakeBomb Garage!
The FPSpëc remote damper adjuster for Ohlins DFV's allow for full control of your dampers, with a simple turn of a our remote panel mount knob, anodized to match Ohlins suspension. With care to design and detail, we custom engineered every component in this kit to reflect the quality of Ohlins suspension. Simply slide the lower billet hard-anodized aluminum cap over your standard gold Ohlins adjuster knobs and fasten in place with the set screw (ball end allen key included). Insert the remote adjuster cable, and run to the desired panel mount location. Add the remote knob and you're ready to roll. All parts designed and manufacturered by SakeBomb Garage. Our high-flexibility remote adjuster cable with low friction PTFE sleeve allows for fine tactile control of the damper knob (you'll still feel every click as if you were adjusting the damper directly). Custom sized for your application (and available in custom lengths for bespoke applications).
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Pictures of them installed in interior panels:
Note: does not work with spare tire
__________________
***We're currently assembling these for shipment... please give us a week or so everyone.
We shipped the first 5 we had a in stock literally the morning after we publicly released the remote adjusters for the S2000. We absolutely didn't expect this much turnout, so we're a bit caught off guard. Thanks for the support and enthusiasm everyone, I can guarantee this will not disappoint! I can't imagine not having these in our shop cars after running them for a couple months for testing.
If you've got questions or comments please keep them coming, happy to answer questions if you've got them. Just to note, these will not work with the spare tire in place as the tire literally sits on TOP of the Ohlins adjuster (this is the same issue for all aftermarket suspension however)
__________________
Batch of another 10 should be ready to ship Monday! Thanks for the orders everyone!
__________________
Not a problem! Email us at info@sakebombgarage.com and let us know when you'd like to come by. We will probably add that option to the website soon as well because a lot of customers have asked for that option. Many people still want to keep their spare and it totally makes sense.
__________________
