URGE Flow Rear Rotors; NOW IN STOCK
Sponsor
Flow Rear Rotor Details
• 2 Piece, Vented (40 Straight Vanes), Floating rotors w/ 7 Straight slots
• 282 x 16.5mm (OEM is 282 x 12mm solid)
• Anodized 6061-T6 Aluminum Hat w/ Spring Clips
• 8lb mounted weight, Saves 4 lbs of rotational & unspring weight (2lbs per rotor)
• Our Product Page
[attachment=79055:Flow Rear Rotors.JPG]
Benefits
• Reduce likelihood of rear bearing failures due to overheating rear rotors, $1000+ Repair
• Improved Rear Brake performance due to rear rotors not overheating & possibly more aggressive pads
• Reduced Front Brake Wear due to rear brakes carrying more brake load
• Overall Braking Performance improvement due to better brake balance
Testing Feedback
• Customer has been road racing, time trialing & professionally prepping cars for 20+ years
• Track records at 3 different track in 2 different cars
• AP2 Supercharged, 390-450 WHP depending on event/class
• Hoosier Tires, 3150 lbs w/ Driver, Street legal & full interior
• Testing done at VIR, 3 day weekend, 9 20-30 min sessions.
“The short story is the car stops better-my lap times improved (I made no other changes)-my brake zones (2 areas from max velocity to threshold braking) where compressed-the "balance" of the car under braking is much improved-my car liked the fact that there was "more" rear brake-car is more stable under threshold braking-rear brake pad wear has reduced (I did not change brake compounds, I run Carbotech pads). I don't like that the brake pads need to be shaved but I have learned that every time you modify a car, there has to be a compromise, so shaving the rear pads is just a little compromise to get improved braking”
Note; Customer normally replaces Stoptech rotors after 2 weekends/12 track sessions due to cracks. The customer noticed no Stoptech cracks after 9 20-30 track sessions using our Flow Rear Rotors
Rear Pad Management
• When installing 2 new pads, each pad needs 2mm shaved off
• OR 1 new pad can be installed with a partially used pad, Continue swapping pads to maximize use across both sets of pads
Rear Bracket Modifications
• 1.5 mm needs to be removed from the long, inside of the bracket & 3 mm from the short, outside of the bracket
• We can do this for $50 + $75 refundable core swap (US only, International must modify locally)
• US customers can modify themselves to save time & money
[attachment=79056:Rear Caliper Mod.jpg]
1. URGE Flow Rear Rotors $700
2. Girodisc Front Rotor Combo $700 + $700 - 10% combo discount = $1260 + Shipping
3. Essex BBK Combo $2350 + $700; $300 off Race Pads/Shipping & $100 off rear rotors = $2950 - $300 off Race Pads & Shipping
Replacement Discs cost $175 per Disc & Replacement Hats cost $350 per pair
Girodisc is our manufacture and URGE is the investor and has the exclusive rights to these Rear Rotors.
• Our Product Page
Benefits
Testing Feedback
Rear Pad Management
Sponsor
Target Shipping is end of June.
Sign up
1. SA; Rear Rotors, existing URGE BBK owner (1st Commit, Thank you!!)
2. VehicleFX, Rear Rotors, existing URGE BBK owner
3. Local Buyer, Rear Rotors, existing URGE BBK Owner
4. S4Speed, Rear Rotors, new customer
5. Bullwings, Rear Rotors
6. kt411gcn, Rear Rotors
7. michaelnyden, Rear Rotors
8. imstimpy , Rear Rotors
9. wowwitsgau, Rear Rotors, Existing URGE BBK Owner
10.
11.
12.
13.
14.
15.
Sign up
10.
11.
12.
13.
14.
15.
Who is the supplier of the rotor rings? In the event that Urge is no longer around, how would one go about replacing the rings (assuming the rotor hat is still viable)?
Also, i'm assuming that once the bracket has been modified, it is no longer compatible with the OEM solid rotors? Please confirm. Thanks.
Sponsor
The bracket modification does not effect the ability for the stock rotor to be run. You should be able to change them out as needed.
Sponsor
Is the Rotor hat any thicker or thinner than the Stock Brake Rotors?
Just wondering if it affects the offset of the Rear Wheel in regards to pushing the wheel out or pulling the wheel in.
Especially when running wide rear tires the clearance with the rear wheel fenders can be very close.
Thanks.
Thanks.
Sponsor
Thanks.
Thanks.
The Test car was running stop tech trophy kit. The customer had that kit we had our kit in production.
Please add me to the group buy list = Andrew SA, Australia
Existing Urge customer with Essex AP front BBK. I have no affiliation with Urge and can say with confidence after dealing with heaps of vendors around the world that their service, R&D and products are 2nd to none. If you are serious about track work you will quickly find the caliper mod and pad shave are the very smallest of compromises to make. Thank you Urge for pushing into new territory with the S2000 allowing regular guys like myself to punch well above our class out on track!
Cheers
Andrew
Cheers
Andrew
Urge, we have a few people in aus who love the sound of this, problem is the aus $ is so bad they end up a fortune for front and rear set. Can basically buy a bbk.
Hopefully you keep working with girodisc for a while and in the near future we can put some orders in.
Awesome
Awesome
