Compression height & Deck Height (F20C)
Would anyone happen to know what the compression height of the F20C piston is?
Deck height of the F20C Block? Do they differ between the F22C and the F20C? I tried searching but I didn't get any particular results. Any input would be greatly appreciated and would save me a lot of time. Thank you in advance! Cheers, fly_S2K |
I was able to find out what the compression & deck heights for the F20C were.
F20C piston compression height (pin hole to piston deck)- 30mm Deck height for both F20 & F22 - 223.9 mm I did not find if the compression height of the F22C pistons were the same as the F20C pistons, but I believe they would be. For anyone who ever wants to know. |
how are you defining deck height. I was under the impression that deck height is the height difference between the top of the piston at TDC and the top of the engine block not counting the thickness of the head gasket.
can you clarify this? I am looking for this information. Thanks. |
