120,000K service
I have a list of additional stuff over and above the service items. Will let you know if they find anything significant.
Andy
Originally Posted by lovegroova' timestamp='1430841268' post='23602177
I have recently asked them to either to a Honda 12, plus any other bits that need doing according to the 9,000 schedule in the FAQ, as it can work out cheaper.
Additional items are as follows:
Having said that, the last service I had done was the equivalent of the 54k service (162k miles) and it worked out less expensive to go with that as a discount was available on that and not on the Honda 12.
- Air filter
- Valve clearances
- Spark Plugs
- Drive belts adjustment
- Coolant replacement
- Transmission fluid
- Differential fluid
All good.
I did get them to change diff fluid and do the valve clearances, more for peace of mind than anything else.
Other than that 2 new front RE050MZs. The originals were split in the tread - they had been on there a long time. but I did get them to price match the online tyre providers.
Just two other advisories.
- front bushes showing signs of wear
- slight corrosion on rear exhaust box.
all good for the jaunt down to Spain and back next month..
