18s on the S
Originally Posted by NeilB,Dec 21 2006, 08:38 AM
I like those wheels
any more details on make and model pls Lloyd?
They are BK993 by BK Racing. 235/40 FR and 255/40 RR
Ok, they are ET55 rears and you should go for ET65 but I was the trial person, the first ever person to put them on the S2000, could of had them altered to the ET65 but fell in love with the blown arch look that it gave and decided to stick with them.
I reckon it has improved the handling having that extra width at the rear.
Take a look>>
I'm currently looking for a set of alloys 17" or 18". I keep hearing the phrase 17 for go and 18 for show. I can appreciate that some wheels are lighter than others and obviously the offset is quite critical on the 'S'
But I still don't really get it. Can somebody please explain the reasoning behind the phrase
Does a good quality 18" alloy wheel really detract from the performance of the car as opposed to a 17" wheel of the same standard?
Thanks in advance for any info
[QUOTE=A7DY W,Dec 21 2006, 09:14 AM] I'm currently looking for a set of alloys 17" or 18". I keep hearing the phrase 17 for go and 18 for show. I can appreciate that some wheels are lighter than others and obviously the offset is quite critical on the 'S'
I guess I should explain that!
Simply put, sprung weight is everything from the springs up, and unsprung weight is everything from the springs down. Wheels, shock absorbers, springs, knuckle joints and tyres contribute to the unsprung weight. The car, engine, fluids, you, your passenger, the kids, the bags of candy and the portable Playstation all contribute to the sprung weight. Reducing unsprung weight is the key to increasing performance of the car. If you can make the wheels, tyres and swingarms lighter, then the suspension will spend more time compensating for bumps in the road, and less time compensating for the mass of the wheels etc.
The greater the unsprung weight, the greater the inertia of the suspension, which will be unable to respond as quickly to rapid changes in the road surface.
As an added benefit, putting lighter wheels on the car can increase your engine's apparent power. Why? Well the engine has to turn the gearbox and driveshafts, and at the end of that, the wheels and tyres. Heavier wheels and tyres require more torque to get turning, which saps engine power. Lighter wheels and tyres allow more of the engine's torque to go into getting you going than spinning the wheels. That's why sports cars have carbon fibre driveshafts and ultra light alloy wheels.
The tyre acts as part of the suspension of the car.
HTH
Changing from 16" standard wheels and crap (non standard) tires to 18"'s with toyo proxies. The car felt a bit higher and the speedo is out more compared to GPS.
The ride was noticeable harder, bumpier but the grip was much better , if I wanted a realy comforting ride I'd have bought a BMW or something
Idealy I think I'd go for 17's I think but I like the look of 18's now
Member
You could go for 17 front and 18 rear as some have done. I think this looks good, as 18" on the front can look ridiclously big.
Either that or just go for 17 all round.
I had 18's - never again.
MB
MB
