2009 slight knock. More of a fast tap on start up
only lasts 5 min or so. also ive had my car for two years now but was just reading some stuff about the 2009s being a bit of a pig. cant be true can it.
I would be a little worried - got a video?
i dont am not to handy with that sort of thing. the wee car only has 30.000mils on it an i dont drive it that hard. will try get i video up 2moro.
They had issues with an incorrect build, some washers on the crank?
Get someone knowledgeable to look/listen Good luck |
yes i must get that looked at. am starting to think that wee knock/tap noise is the time that takes the oil to get round the engine cas its not drove that much. surley that noise wod last more than 5min if it was something major like the crank. just thinking outloud
Oil circulation would be seconds, not minutes. 5mins is likely to be something else, related to heat build up, eg piston slap due to tolerances closing up as it warms up.
What oil are you using and have you checked the dipstick?
if it was piston slap. is that a bad thing
Originally Posted by flanders
(Post 24425175)
Originally Posted by alvin moore
(Post 24425180)
