5-5.5k resonance issue? Buzz/tinny hi-freq rattle.
Apart from Coxyboy, does anyone get a 5-5.5k revs high freq buzz, like a heat shield rattle?
It occurs in neutral as well as when driving and is almost certainly shield related. It happens ALWAYS on 5k-5.5k.
Any takers?
Any takers?
There are 3 exhaust heat shields from the manifold down to the CAT these are held by bolts and washers, I have known these to come loose and even drop out in one case!
You could be getting some resinance from one of these?
I'll get all three heatshields checked today (hopefully) when I pop into Tachbrook Honda, and i'll post a bit later this afternoon.
Cheers
Coxy
Nigel,
cheers for that comment. Well it all started post HKS installation. So I`m sure thats where the issues lie. Axle stands aren`t the best thing to check with I really need it over a pit or ramped. Thats what needs to be looked at first.
Originally posted by Coxyboy1
CC
Cheers
Coxy
CC
Cheers
Coxy
cheers mate. I REALLY REALLY REALLY want to hear what you find out, coz I`ve been bugged by this. Please let me know
ta
Col
Originally posted by cheshire_carper
Coxy
ta
Col
Coxy
ta
Col
When I had the HKS I had a subtle rattle coming from seemed like the dash - but it was the rear view mirror - tightened it and everything is fine. I would put it down to the droning frequency which messes things up a bit. Since putting the Amuse on, everything is fine. I did check the heat shields though - I was able to tighten them a teeny weeny bit.
CC - you better jack the front up and get under there - you don't want to be losing heat shields whilst driving.
