ABS sensors
ABS sensors
What is the best way to remove the ABS sensors from the hubs?Iv removed the 10mm bolt and soaked with Plusgas but Im a bit nervous about getting then out(every Fecking job I do on the car creates another,Aint that true Rassele)they do look a bit fragile.Before anybody asks,its so I can remove the hub from the car to put extended wheel studs on,and before anybody asks
Ill answer my own question,I used a very small chisel between the hub and the ABS sensor and tapped very carfully a couple of times and it came out.I will clean it and the hole in the hub with wirewool and copperslip when I refit..Thanks for all your help
ayashifx55
03-17-2011 07:47 AM
