UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Accord type r twin pot caliper upgrade info needed..
Here are few pics. Size difference and mountet!
only thing that has to be done is bent or cut the brake dust shield! But this has to done to all other bbks!
i ave test fitted the caliper to the car all that was needed was a trim to the heat sheild.
The clearance of the carrier and disk is fine but a little offset which can be sorted with very little machining ( if you want to go to the trouble of doing this which i will be ) also note the metal spring clips that hold the pads in was very close to the disk which a little bit of bending will sort this out
