Adjustable roof catches
#22
Member
I'd guess the crosshead screw has a taper on the face of it, so it won't hold in place very well. Allen bolts are flat on the face and give a better hold. You can also exert more force on an Allen bolt than a Phillips screw.
#23
Finally got round to doing this today, the difference is unbelievable! I reckon I'll not need to turn up the volume past 10 now! Hopefully it might magically sort out the other problem of water falling on the passenger side!
I was anticipating all sorts of hassle to loosen the screws but a simple screwdriver sorted it no problem!
I also used a drill bit and slowly moved sideways with it to open up the holes, took a bit longer than whoever did it in 20mins but didn't have a dremel.
Overall very simple mod to do and I've got a bag full of the M6 x 20mm bolts left over so if anyone wants some just PM me and donate a quid to a charity or something!
Thanks Shopman for figuring this out!
#24
yes one of the original screws is a CSK so will not locate properly in a slot.
Be careful of the suggested "cheese" head screws as they are prone to have the female hex for the allen key rounded out. Its a smaller size key for the same thread size.
Also note you can get a "file bit" to fit in an ordinary drill if you don't have a Dremel.
I just whacked a 6mm dril through next to the original hole and then filled it out to a slot with a 1/4" rat tail file. But I do this sort of thing all the time so do be careful. I had no trouble getting flat washers with shake proof washer under the head of the bolt's i used which were ordinary Hex heads
#28
