Advice needed - grinding noise and feel from the front drivers side - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > International Communities > UK & Ireland S2000 Community
Reload this Page >
Notices
Old 02-11-2018, 03:31 PM
dazza1990's Avatar
Default Advice needed - grinding noise and feel from the front drivers side
First, my front offside caliper seizes. Then my brand new rotrex charger is faulty out of the box. Now I finally get the car back and it's making another noise.
When the car is up to temp, I'm getting a grinding noise coming from the drivers side front of the car, especially when turning left. Nothing when turning right. Doesn't do it when cold, only warm. In or out of gear and I can feel the grind coming through the brake pedal.
Ive had a quick search, the suggestion of wheel bearing comes up often. Car is just under 40,000 miles.
Anyone else had this?
dazza1990 is offline
Old 02-12-2018, 03:37 AM
Nottm_S2's Avatar
The caliper could have cooked the bearing.. jack it up and spin it.. maybe when warm?
Remove pads and spin again
It could be something odd like the heat shield fouling if someone or thing has bent it or something is trapped in it
Nottm_S2 is online now
Old 02-12-2018, 06:29 AM
dazza1990's Avatar
Yeah, I'm going to give it a shake down tonight. Warm it up, jack it and rock the wheel to see if there's any play. Check over the pads too. Is it possible it cooked the bearing? Seems coincidence that it's the same side and not much time spent.
Fellblade
03-27-2018 01:00 PM
tomair
06-30-2015 08:28 PM
Brando
Tampa
02-15-2010 01:31 PM
TheTownAbbott
03-23-2009 04:00 PM
BENJMNS
08-05-2005 04:44 PM
Quick Reply: Advice needed - grinding noise and feel from the front drivers side
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
