Air con re gassing
My car needs doing too, the AC dosen't even switch on its so low on pressure. there is a site glass in the high part of the pipework under the engine bay where you can see if its low or got air bubbles in it when its running. I can't see anything in it, think I've got a leak somewhere :-(
My old car required it to be serviced every two years - is it the same with the 'S'?
I was thinking of having it done at its 2yr service on Friday. It's working perfectly well now, but like to keep on top of these things!!
been through all that process on an audiA4.. eventually got them to put a dye into it and spot the leak with a UV lamp - similarly expensive in the end.
