Alarm woes - won't stop going off!! Help! - Page 2 - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > International Communities > UK & Ireland S2000 Community
Reload this Page >
Notices
Old 07-21-2018, 05:13 AM
unclefester's Avatar
If the alarm is continuing to go off then it 's not disarming properly or is continuing to arm itself and that's nowt to do with the boot sensor. Sounds more like a fault with either the fob or the main alarm unit.
unclefester is offline
Old 07-22-2018, 05:40 AM
I have just purchased an 06 and once the alarm started a low pitch tweeting noise under the hood, once I got stopped it stopped in a few minutes,
i have a an issue with something draining my battery and I think it may be the alarm,
Is there a fuse or someway to disconnect the alarm to see if that’s my issue?
Beetlevtx is offline
Old 08-19-2018, 05:15 AM
Thanks for the suggestions guys!!
I had some time today so go the S2000 out of the garage and into a position where I could work on the interior comfortably!
I looked above drivers knee as suggested, found a white box (marked lock assy or something similar) and a black boc. Tried with either connected but no joy.
Siren is located behind the filler pipe as suggested above, with it unplugged my CL/immob work as normal.
I could remove my siren from within the boot area, I suspect this is the problem....
by https://www.flickr.com/photos/[email protected]/, on Flickr
I don't reckon it is taking a charge anymore, or maybe it is taking longer than normal. Does explain why I could get it turn off and stay off the other week, as long as I didn't actuate anything else on the car - but I had left it overnight in that state with battery connected, so the siren battery can't be any good.
I'll source a replacement battery and hopefully all will be well!!
hallsy is offline
Old 10-01-2018, 05:32 AM
Where can you get fob/ alarm system replaced. I live in Hampshire. Honda dealership just keeps fobbing me off
This is my fob Battery is fine but fobonly works intermittently
micymays is offline
Old 10-01-2018, 05:33 AM
micymays is offline
Old 10-01-2018, 05:57 AM
nomadicS2k's Avatar
This is the HP alarm system - pick up the phone to them - they are based in Essex and can provide reconditioned items etc.
nomadicS2k is offline
Old 10-01-2018, 06:22 AM
Thanks I have already rang them they say they don’t supply this any more
micymays is offline
Old 10-01-2018, 07:02 AM
nomadicS2k's Avatar
Blimey - I only bought a new main board this time last year. Any more problems and it will be a new alarm!
Old 10-01-2018, 01:05 PM
Default Now the have seen a photo they say they can help will drive to Kent to see them help
Now they have seen a photo of my fob they can help me.
micymays is offline
Old 10-02-2018, 01:42 AM
nomadicS2k's Avatar
Great news!
Quick Reply: Alarm woes - won't stop going off!! Help!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
