Alignment fast road setup
Took my car in for a geo bolt check, seems ive got lucky and don’t have any rusted up ones. They didn’t have time to actually do a an alignment setup - so taking it back in next week. The guy seemed to know his stuff, but is there a preferred fast road setup? I Don’t do many miles in it, so don’t mind a bit of extra tyre wear for some more grip |
BTW Excessive toe wears tyres not camber :tipwink:
If the suspension is standard, then a fast road set is the standard set up, the S2000 is a fast road car, ego standard is fast road car set up.
Originally Posted by richmc
(Post 24499079)
find that hard to believe |
A well set up S in standard form with good tyres, has more potential than most of the owners who drive them. A few lower braces can help a bit, without going to mad expense. |
Originally Posted by Oilslick
(Post 24499080)
So there is no way to improve grip over the standard setup? find that hard to believe |
(Post 24499264)
Pretty much, Honda designed a sports car, they had engineers who know how to do that very well, why question that? It was designed to drive like a sports car. Go on a limits day with it you will discover it's potential.
My advice is to use the standard settings for your model year (MY03 and previous or MY04 and afterwards) which can be found in the FAQ. Then add a bit more camber. Job done.
Before diddling with the alignment (other than making sure it's in the OE settings) make sure you're running performance rather than all season tires. Either of the top two tiers, Extreme and Max Performance. Available tires vary by geographic market.
-- Chuck |
(Post 24499264)
