Alignment fast road setup
Took my car in for a geo bolt check, seems ive got lucky and don’t have any rusted up ones. They didn’t have time to actually do a an alignment setup - so taking it back in next week.
The guy seemed to know his stuff, but is there a preferred fast road setup? I Don’t do many miles in it, so don’t mind a bit of extra tyre wear for some more grip
BTW Excessive toe wears tyres not camber
Pretty much, Honda designed a sports car, they had engineers who know how to do that very well, why question that? It was designed to drive like a sports car. Go on a limits day with it you will discover it's potential.
That's a pretty narrow minded way of looking at it. Honda designed it with adjustability in-built. They tried to balance the best setup for most of its buyers, which certainly wasn't a 'maximum grip' setup. It takes into account tyre wear, changing conditions etc too. They also changed the setup over several iterations, which proves no one setup is ever perfect. It is also a very personal thing, preferences are different for everyone and everyone uses their car for a different balance of purposes (track, road, cruising, shows etc). There is plenty, therefore, you can do to adjust this car to make it handle to each driver's preference.
UK Moderator
My advice is to use the standard settings for your model year (MY03 and previous or MY04 and afterwards) which can be found in the FAQ. Then add a bit more camber. Job done.
Before diddling with the alignment (other than making sure it's in the OE settings) make sure you're running performance rather than all season tires. Either of the top two tiers, Extreme and Max Performance. Available tires vary by geographic market.
-- Chuck
-- Chuck
why question that? Because I’d like it to be the best it can.
