This Alpine unit with the Modifry DCI?
Hi all,
I've been offered a fairly good deal on the HU (below)
The exact model doesn't come up on the Modifry website so just wanted to see if anyone else had it and if they can confirm that it works ok with the DCI
Thanks in advance and apologies for adding yet another ICE related question to the forum.
Dan
CDE-9871R/RR CD / MP3 RECEIVER Feature:
Full Speed Connection for iPod
Quick Search
CD Text Display and Scroll
CD-R / CD-RW Compatible
MP3 File Playback
MP3 Text Information Display (ID3 Tag)
Regulated 1-bit DAC
Zero Data Mute (0 bit Mute)
Connectivity:
OEM Steering Remote Control Ready
AUX-In Ready (w.KCE-236B)
Power Specification:
4 x 45W High Power Amplifier
2 Preout with Subwoofer Level Control
Display:
14 Segment Black Mask Display
White LCD Lighting
Audio Processing:
High Pass Filter@(80/120/160Hz)
Bass/Treble Center Frequency Adjustment
Bass Band Width Adjustment
Other Highlights:
MaxTune Tuner
Rotary Encoder Volume Control
Detachable Face Plate
ISO Connector Ready
Quick Search
MP3 File Playback
Regulated 1-bit DAC
Connectivity:
Display:
White LCD Lighting
Audio Processing:
Other Highlights:
MaxTune Tuner
ISO Connector Ready
Dan
It's all pretty generic so should be fine.
I originally had the CDA-9812RB then replaced with the iDA-X001 and my DCI worked with both.
Otherwise email Bob (Modifry) and he'll confirm.
Make sure you get his Plug-n-Play harness too which connects the stock harness to the DCI to the HU in one hit. It avoids any splicing and makes the install very straight forward.
Originally Posted by tomkbucks,Apr 9 2008, 03:32 PM
only reason id want the new x300 unti is for the album art
Lovegroova - Alpine HU's iDA-X001, iDA-X100 & iDA-X300. The first two show the album art if it's loaded onto your iPod. It's v but also kinda pointless if you keep the radio door shut!
I got my ida-X100 last weekend.
Great head unit, if a bit slow to scroll through artists - nowhere near as fast as the iPod itself but live-able with.
Album artwork only displays if you use the USB cable. Same with fast scrolling through the alphabet. Sadly I only realised that _after_ i'd installed and put the car back together.
Thanks for the info guys. I dropped Bob an email and he confirmed that the DCI will work no problem.
Next question...
Could someone please point em in the direction of an ICE install FAQ?
Thanks again,
Dan
Next question...
Thanks again,
Dan
