Amplifier installation...
So what have you guys done? Now im doing the racing im wanting to make the s2k a bit more long drive friendly, so im planning to fit my stereo gear to it at last. Question is, where have you put amplifiers in the car? Theres not much room, to fit in 2, and id rather not fill the boot with amps (plan to have the sub easily removable in there incase i need the boot.)
Any suggestions/inspiration?
Either side of the boot
Over the fuel tank
Inside the space saver
Slimline under the passenger seat
Make it part of the sub box so the whole thing comes out.
Over the fuel tank
Adrian, there are plenty of amp install threads including in the Electronics section. I ditched my spare wheel and made an amp rack to install a 5 channel Alpine sub. Since then I've changed to a Genesis Profile 2 channel amp and made an amp rack which sits within the spare wheel instead. Very discreet and the quick connectors I've used mean I can remove the amp quickly if the spare wheel is needed.
UK Moderator
What fester said.
Lots of ideas and maybe some pics in this thread https://www.s2ki.com/...ovideo-systems/
I have two amps mounted over the fuel tank, works a treat.
You can make a board that screws down with the spare wheel bolt which will hold two amps, there is JUSTt enough height to do it. However that space gets lower the further back you go, by a good 2 inches so make sure if you do take a height measurement, you measure it as far back as your deepest amp.
