Another help please - Headlight auto adjustment - bar broke (MOT Failure) - Buy???
Old 11-03-2017, 07:40 AM
BledS2k's Avatar
Question Another help please - Headlight auto adjustment - bar broke (MOT Failure) - Buy???
Hi all,
So as well as my other post, it seems the auto adjust on the headlights isn't working also.
Mechanic has said the bar that links to rear axle to the sensor has broke; short bar with x2 ball ends on has sheared.
Can anyone help advise where I can get a replacement from? I don't really want to buy a complete system from OEM as that'll no doubt cost a fortune.
Thanks
Brent
Old 11-03-2017, 08:21 AM
UK Moderator
lovegroova's Avatar
Ask Si at Hendy (see the traders section) to find out the cost from Honda. Better that than making assumptions which may or may not be accurate.
Please also see the rules relating to"Where can I buy" threads: https://www.s2ki.com/forums/uk-irela...-first-131836/
Old 11-03-2017, 09:11 AM
BledS2k's Avatar
Hi Lovegroova,
I've spoken to the guys at Hendy & they said I'd need to replace the whole system at considerable cost (couldn't see separate parts).
I had assumed this would be a common fault or at least it may have happened to some others also?
My apologies if I'm in breach of the rules, it's not intentional & I must say sadly it's been a while since I've posted - been on the forum for approx 10 yrs.
In this instance I'm looking for advice only in the hope of pointing me in the right direction, perhaps even a DIY fix?
Is this ok?
Old 11-03-2017, 10:14 AM
E4RTH WORM JIM's Avatar
Remove it and repair
Old 11-03-2017, 10:44 AM
tozerman's Avatar
I agree, there is a thread on the US side where someone did a diy they got some bar and threaded it left one end right the other and got some small threaded ball joints. Worked a treat apparently...
Old 11-03-2017, 10:58 AM
f20rob's Avatar
I'm doing this right now. The OEM joints are made by THK Japan, but they're difficult to get hold of over here. I'm currently waiting for a UK supplier to get back to me with costings and I'll report back.
If you're going down the DIY route you'll also need an M6 linkage rod. Be careful of cheap quality ball joints though; I bought a pair and they were crap.
Alternatively, you might be able to find a whole assembly on eBay if you're lucky.
Old 11-06-2017, 07:39 AM
BledS2k's Avatar
Hi Tozerman, cheers I found a link to a guy in the UK that's done it
https://dave.harris.uno/s2000-diy-re...stment-sensor/
f20rob - Ok sounds interesting, do you have a timescale on getting hold of the parts? & costs? (PM me if not appropriate to write on the post).
Thanks
Old 11-07-2017, 09:01 AM
f20rob's Avatar
£23.30 for both the joints and £35.95 for the shipping. Add 20% VAT on top of that and it'll cost you £71.10 to get them over here.
There are definitely cheaper alternatives, but I decided to go ahead since I've invested so much time in tracking them down! If you are interested then throw me a PM.
I just re-read the title of your thread and I'm wondering if the joints are actually fine and you only need to replace the linkage rod. This would save you a few quid for sure...
https://www.ebay.co.uk/itm/M6x1-0-RH...6/131812853057
Old 11-07-2017, 09:03 AM
f20rob's Avatar
Sorry, forgot to mention: lead time on the parts is approx. 4 weeks
Old 11-07-2017, 09:36 AM
Nick Graves's Avatar
IIRC, the main reason the rod shears (aside from corrosion) is the rheostat's very stiff.
Take it off & clean/lube it.
Quick Reply: Another help please - Headlight auto adjustment - bar broke (MOT Failure) - Buy???
