Anyone fitted a reversing camera/rear dashcam?
I quite fancy the idea of a reversing camera (maybe also acting as a rear dashcam - I already have a front-facing dashcam stuck to the windscreen). Does anyone have any experience of fitting a reversing camera and screen to a UK S2000? (mine's a Jan 2003 model). Where would be the best place to mount the cam and screen, and how/where is best to run the cables?
cables can go along the door sill. The problem with a traditional rear dashcam, that goes into the interior of the car, is that there are limited mounting points. On my CR I mounted the rear dashcam behind the passenger seat head rest, it's easier for the CR because of the fixed rear cover. On my AP2 I mounted it onto my windscreen, but I found it a little low, considering the small rear window; better when I had my hardtop on.
Parts
A) High definition back up camera from AliExpress $7
HD Back Up Camera w/Rotating Lens
B) Video WiFi Transmitter mounted behind trunk liner panel near tail light. Power wired to back up tail light circuit. $35
ireless iPhone Transmitter
C) Download transmitter free App from App Store
D) 90 minutes to install and setup
E) 5.5" Camera image on iPhone 7 Plus
F) Installed in 2014 and still working flawlessly.
Thanks for the recommendations. That camera looks amazing value, but the resolution isn't quoted on the item description - any idea what the resolution is? Also the reviews of the app on Android aren't good - it only seems to work on older versions of Android.
I really like the idea of mounting the camera on a licence plate holder, as it means the hole can be drilled behind the licence plate (just in case I make a mess of drilling the hole!). The problem is that I have a UK vehicle, and haven't yet found anything similar for UK-style licence plates.
I believe that it is 720p.
Sorry to hear that about Android. I've enjoyed mine for a few years now using iOS without regret.
Drilling two holes in the upper hidden area of the bumper's license recess does not really require a great deal of courage or skill.
na2king
09-27-2018 09:13 AM
