AP2 alloys 17 by 7 on rears?
So I fitted some 5zeigen alloys (All 4 17 by 7 instead of OEM 17 by 8.5 on rears) I had to my 04 AP2, still waiting on spigot rings as they weren't sitting right but the car feels very unsettled and seems to want to rotate on turn in.
Also fitted UNiroyal rainsport 3's which I think have a soft sidewall which may be contributing to the unsettled feeling along with the need for an alignment which I'll get done next week.
Love the alloys but fear the smaller size on the rears may be the main issue and as we all know you don't want the back end feeling unsettled given their love of swapping ends....thoughts?
Cheers Dave for the input, there's definitely a vibration in the steering that wasn't there with the OEM wheels so they're not sitting right somehow.
The rings should arrive tomorrow and I'll get geo done next wednesday, thereafter will look at getting a matching pair of 8.5's for the rear which isn't a total pita as 2 of the wheels are starting to de-laquer.
On the geo, has anyone a printout of fast road settings just in case the local crowd don't have them?
Dave - Could be alright, wheels were balanced before fitting new rubber, so will take the wire brush to the hub before I fit the rings, thanks for the heads up on the geo.
dj - Still running 245's on the rears but you can see the sidewall bulging over the wheel and the rainsports are known to have a soft sidewall and it feels exactly as it looks, ie the car shifting under you as the weight transfers. Have 225s on the front so likely not helping either.
Having parked an AP1 in a ditch after I ran out of talent while exploring the limits on a late night hoon, I'm all to aware how sensitive these are to changes and the best advice being not to mess too much with OEM parts and settings...
Can't be terribly safe running a 245 on a 7J wheel, it must be really bulging over. Someone posted a very handy guide on here not long ago showing what tyre widths were within acceptable limits for wheel width.
I seem to remember the minimum on a 7J was 195, ideal was 205/215 and max was 225. These are all safe options from memory.
http://www.brick-yard.co.uk/forum/tyre-size-for-rim-width_topic60146.html
A guide found after a quick google. Useful for wheel width and what tyre widths to use for the wheel size you have.
