Headlight Restoration
Well I had tried the usual simple solutions to try and remove the haze from my headlights. You know, T-Cut, toothpaste etc. Never seemed to make much of a difference, so I decided to take the plunge and do it properly. I used the 3M kit - this one:
I watched a few video's on YouTube, and they were pretty frightening, but I decided to give it a go.
The initial stages are the worst - I decided to wet sand all the stages, but stage 1 and 2 you can do dry if you want. Stage 1 is 500 grade:
Then 800 grade:
Then 3000 grade:
And then rubbing compound. This is the bit where you see the final result:
It took me a couple of hours, but it was well worth it.
Then 800 grade:
Then 3000 grade:
Just as long as you are aware you will need to keep doing it - the UV protective coat is now gone from the plastic and it will haze over again. I probably do mine 3 or 4 times a year to keep them nice.
Has anyone tried anything like this: https://hbc-system.com/en-gb/product...ective-coating to apply a new UV protective coat?
There's also a DIY idea which sounds mildly terrifying here: https://www.autogeekonline.net/forum...lant-idea.html
Yes, I realise this. The car is going to the bodyshop to get the wheelarches sorted, so I'll ask them to clearcoat the lenses at the same time.
Just use a really good wax with a high UV resistance. The best I know of is 3M Marine Protective Wax. I've used it a lot on boats and it used to have the highest UV resistance of all. It works fine on the headlights.
Fellblade (05-06-2018)
You can avoid doing it multiple times, I followed this guys instructions on a previous car, only ever did it once.
https://www.youtube.com/watch?v=UEJbKLZ7RmM
