Ball Joint Boots in the UK?
Replacing the bushes in my suspension lower arms and I've had to use a ball joint separator (not a pickle fork!) to remove them because a bloody big hit with a hammer didn't work. I was pretty careful but pushing the prongs past the ball joint has forced some grease out - unsurprisingly. I'm looking to get some spare boots in because although I could remove the boots and re-fill, if I screw it up and damage them I want spares on hand. Which leads me to...
...where on earth do people get them in the UK? Online OEM ones seem to be about £11 each plus postage, and the ebay offerings seem to be generic ones that I have my doubts about putting on my S! If the answer is "don't be a cheapskate and pony up for the OEM ones", then fair enough, but I thought I'd check - some references from the US side of the forum have talked about getting them for $2 each!
http://www.balljointboots.co.uk/
Measure up and order, great prizes and service.
I think the rear ones were about £3 each. Don’t both with cable ties, you can reuse the spring clip, just use plenty of WD40 when sliding back over the boot.
