Ball joint seperator
Old 08-30-2015, 11:25 AM
Carbon S2K's Avatar
Default Ball joint seperator
Hi guys Ive never done this job before so I would like a recommendation on a ball joint separator for the wishbones/ tie rod ends etc?
Thank you
Old 08-30-2015, 12:08 PM
rmerchant3's Avatar
Thank you
Honda makes a special tool for it, but a very large hammer works just as well if you don't want to shell out the money for the tool.
Old 08-30-2015, 12:56 PM
RobAp1's Avatar
+1 for a hefty hammer.
You're best to undo the nut and smack the side of the arm/hub where the ball joint goes through. Whatever you do, don't smack the top of the ball joint with the thread on it unless you don't want to use it again
Old 08-30-2015, 02:18 PM
Ultra_Nexus's Avatar
Go into Halfords and buy this:
http://www.halfords.com/workshop-too...rator-scissors
Job done.
Old 08-30-2015, 02:26 PM
LEEF's Avatar
Ball joint splitter £8 on eBay
Old 08-30-2015, 02:30 PM
Nottm_S2's Avatar
I would get a press one like that linked one. I used a hammer and a wedge and cracked a suspension arm once
Old 08-30-2015, 02:34 PM
Yeah there are cheap ones on ebay, but they are a bit hit or miss. I only put the Halfords one up because it's easy to get hold of
Old 08-30-2015, 11:58 PM
heymynameismark's Avatar
+1 for that Halfords one
We've had one in our kit for easy 10 years and it's never let me down.
Old 08-31-2015, 03:00 AM
Carbon S2K's Avatar
Thank you very much people. I have a couple of more questions now sorry.... 1)Do I completely remove the castle nut or wind it down some and press against that? 2) how do I go about removing the ball joint from the wishbones, do they just press in/out?
Cheers fellas your a great help.
Old 09-01-2015, 02:56 AM
If you are using the separator, you can take the castle nut off.
Quick Reply: Ball joint seperator
