Bbk with 17inch enkeis/Rotas/Ultraleights
Member
Hi Aaron, there's loads of threads on this...
Below is one for Stoptech wheels for example.
https://www.s2ki.com/forums/s2000-br...thread-771731/
I use Enkei PF01 which are perfect offset and caliper clearance.
But I'd really advise searching a lot more as most things are covered already.
UK Moderator
Do you mean the CP5200 calliper?
The only reason I ask is that AP do an "off the shelf" kit for the S2000 and I was hoping (if you didn't live too far away from Norfolk), to take a ride over to you and if you didn't mind, try my wheel on your car to see if I have sufficient clearance to fit such a kit .
I run the V1 17" 8.5" rear on the front with a 15mm spacer (which changes the offset from ET65 to an ET50) and don't want to change the wheels.
I am circa 4 hours away from you near Wrexham in North Wales to give you an idea mate.
Ever find yourself over this way, drop me a message.
