Big Gay Wing
Member
Yes, I think you want it as far back as possible while maintaining as strong a mounting location as you can.
The Ings one is interesting as it bolts to the rear of the boot, but the actual wing hangs back aver the lid itself.
I guess if you position it further forward, the effects of the wing are reduced at higher speeds.
UK Moderator
Noob question, are you going to do something to the front of the car as well, I imagine that just adding a big wing might lead to understeer (which might sort of be what you want)?
Member
Track tyres and a wing is what you want.
As for the front, I haven't got a standard front end but I guess it's a question (and a valid one) for Raz.
there are cheaper options on ebay then the ones mentioned above,
£700+ for a carbon spoiler is a bit much to have a name brand one,
as long as the mountings brackets are well made and the spoiler is made from decent material then a £2-300 ebay one should do the same job?
Member
Does that come with proven design and testing Rob? You can't just bung something on and hope it works because it's a wing and it's made from carbon?! I repeat that this isn't a looks thing.
APR data here (page 2)
https://www.s2ki.com/forums/index.ph...ic=539948&st=0
